Full Version: "Kill Bill" BD Dosen't Copy Well
I have copied my "Kill Bill" Vol 1 and 2 Blue-ray movies using AnDVD HD as Rip video and also as Rip Image. In all cases the movie that shows in XBMC has a Spanish (or Portuguese) audio with English subtitles that flash very quickly and then disappear.
When played directly as Blue-ray they ask the language etc and work fine with English audio.
Is there a better way to rip them into XBMC? Am I doing something wrong? I have used the same method for hundreds of other DVDs and Blue-rays.
Cheers,
Robert
I use MakeMKV to rip my discs and select the audio track to to be ripped with the movie. I don't use AnyDVD but does it have a similar option to select which audio stream to rip? If it's ripping all of them found on the Blu-ray just enable the correct stream (and subtitles if desired) within XBMC.
Thanks Rick. Changed audio stream within XBMC and all is well. First time that I have had to do this. Learning every day.
