Ok Here The Deal.. Just redone my xbmc because i lost everything , well i installed 12.0 Frodo version with Confluence Skin
Now my thing is im having issues with getting the Cinema Script to Run and also I did install the Repository.Googlecode.xbmc-addons File From The Zip.. Keeping Error and saying Cinema Experince Not Working , Secondly i know ppl preferr Debug log
well I Cant Find It......On My PC.. Can some one help me plase thank you
See here:
debug log (wiki)
And please don't post your log here; instead, upload it to
www.xbmclogs.com and post just the assigned URL here.
im pulling out my hair trying to find dang gum log grrrrrrrrrrr.. i typed in run application data .. buttheir nothing for it ,, i even went to my programs file where xbmc folder is and cant find log
Be sure you have your OS's file manager set to show hidden files.
im redoing it again az we speak soon my hard drive done cleaning so it be fresh install and do eden beta 2 install my
Os; windows xp
Mobo; Gigabyte MA785GM-US2 mATX
CPU; AMD Athlon x2, 3.2ghz
Non-Clocked
Memory 2gb
HDD - 1tb
PSU; 450watt
i just dont understand it i had both these install and it just didnt work
Installed Zip Files
script.cinema.experience
This add-on uses httpapi, which is no longer supported starting with Frodo. This is from your log:
20:37:26 T:10460 ERROR: EXCEPTION: Unimplemented method: executehttpapi::XBMCAddon::xbmc::executehttpapi(...)
See the comments here, which confirm this is currently broken for Frodo:
https://github.com/Giftie/script.cinema....e/issues/6
BTW, I moved this thread to Program Add-ons and changed the title to refer to "Cinema Experience" rather than "Confluence", since this is a problem with this add-on and not with the skin.
Ok Thanks so in other words Cinema Experince Not Compatiable with Frodo Right?
Therefore I Have To Revert Back To Eden Beta 1or2 right?
Sure it is, have you checked the Cinema Experience thread at all?
Link
Yes I Have , And To Be Honest Some Things I Cant Make Heads Or Tails Out Of
I Think I Miss Alot Because Im Half Blind In One Eye, I Love XBMC and That
Cinema Experince Was Perfect For Me Till Dam Kids Screwed Up My Pc
