2013-02-25, 07:13
I have setup the Raspberry Pi to run XBMC, and I want it to boot up to always play a playlist and files on the SD card. I have turned off the Raspbmc automatic update. It still runs okay when I switch the SD card to the "lock" position. Now my qeustions are:
1. Will the "read-only" SD card system works all the time in my application?
2. Since the SD card is always in read-only mode, if I do not use shutdown command, and just turn off the power switch, will it damage my system?
3. Even if this works reliablely, it will always pop-up the message "Raaspbmc did not shut down properly". Is there any way to disable this message when the Pi powers up?
