Full Version: Live TV Recordings won't play - 0 KB?
I'm fairly new to XBMC, so please forgive me if I'm a newb. I have searched throughout the XBMC forums, and I can't find a solution or find a problem that is exactly like this one.
I am running Windows 7 32-bit and have installed XBMC Frodo. I have also installed the latest PVR Next backend as well as the addon within XBMC. I have got to the point where I can watch (and hear) Live TV through XBMC.
I decided to test the DVR feature and set a timer to record a show. It seems the timer was triggered, but the recording won't play. I've tried hitting the "enter" key, the "play" key, and nothing happens. When I look within the DVR directory, I see the .ts files that were created but they are 0 KB?? This has happened on both recordings I've tried. Here is my log file with debugging enabled. Any ideas what's wrong or what I'm doing wrong? Thanks!
19:42:06 T:3780 DEBUG: ------ Window Init () ------
19:42:07 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:09 T:3780 DEBUG: Previous line repeats 5 times.
19:42:09 T:3780 DEBUG: CApplication:TonguerocessMouse: trying mouse action leftclick
19:42:09 T:3780 DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(home)
19:42:09 T:3780 DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(home)
19:42:09 T:3780 DEBUG: Activating window ID: 10000
19:42:09 T:3780 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
19:42:09 T:3780 DEBUG: ------ Window Init (Home.xml) ------
19:42:10 T:3780 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib.dll)
19:42:10 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:13 T:3780 DEBUG: Previous line repeats 6 times.
19:42:13 T:3780 DEBUG: CApplication:TonguerocessMouse: trying mouse action leftclick
19:42:13 T:3780 DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(PVR)
19:42:13 T:3780 DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(PVR)
19:42:13 T:3780 DEBUG: Activating window ID: 10601
19:42:13 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:13 T:3780 DEBUG: ------ Window Deinit (Home.xml) ------
19:42:13 T:3780 DEBUG: ------ Window Init (MyPVR.xml) ------
19:42:13 T:3780 INFO: Loading skin file: MyPVR.xml, load type: LOAD_EVERY_TIME
19:42:13 T:3780 DEBUG: Using already stored xml root node for C:\Program Files\XBMC\addons\skin.confluence\720p\MyPVR.xml
19:42:13 T:3780 DEBUG: CGUIMediaWindow::GetDirectory (pvr://recordings/Jeopardy%21/)
19:42:13 T:3780 DEBUG: ParentPath = [pvr://recordings/Jeopardy%21/]
19:42:13 T:3780 DEBUG: CPVRDirectory::GetDirectory(pvr://recordings/Jeopardy%21)
19:42:13 T:3780 DEBUG: CGUIWindowPVRCommon - PVR::CGUIWindowPVRCommon::OnMessageFocus - focus set to window 'tv'
19:42:13 T:3780 DEBUG: CGUIWindowPVRChannels - PVR::CGUIWindowPVRChannels::UpdateData - update window 'tv'. set view to 11
19:42:13 T:3780 DEBUG: CGUIMediaWindow::GetDirectory (pvr://channels/tv/All TV channels/)
19:42:13 T:3780 DEBUG: ParentPath = []
19:42:13 T:2052 NOTICE: Thread Jobworker start, auto delete: true
19:42:13 T:2052 DEBUG: CPVRDirectory::GetDirectory(pvr://channels/tv/All TV channels)
19:42:13 T:3780 DEBUG: CApplication::ExecuteXBMCAction : Translating Setfocus(34)
19:42:13 T:3780 DEBUG: CApplication::ExecuteXBMCAction : To Setfocus(34)
19:42:13 T:3780 DEBUG: CGUIWindowPVRCommon - PVR::CGUIWindowPVRCommon::OnMessageFocus - focus set to window 'recordings'
19:42:13 T:3780 DEBUG: CGUIWindowPVRRecordings - PVR::CGUIWindowPVRRecordings::UpdateData - update window 'recordings'. set view to 13
19:42:13 T:3780 DEBUG: CGUIMediaWindow::GetDirectory (pvr://recordings/)
19:42:13 T:1192 NOTICE: Thread Jobworker start, auto delete: true
19:42:13 T:1192 DEBUG: CPVRDirectory::GetDirectory(pvr://recordings)
19:42:13 T:3780 DEBUG: CApplication::ExecuteXBMCAction : Translating Setfocus(13)
19:42:13 T:3780 DEBUG: CApplication::ExecuteXBMCAction : To Setfocus(13)
19:42:14 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:15 T:3780 DEBUG: Previous line repeats 2 times.
19:42:15 T:3780 DEBUG: CApplication:TonguerocessMouse: trying mouse action leftclick
19:42:15 T:3780 DEBUG: CGUIMediaWindow::GetDirectory (pvr://recordings/Big Bang/)
19:42:15 T:3780 DEBUG: ParentPath = [pvr://recordings/]
19:42:15 T:2052 DEBUG: CPVRDirectory::GetDirectory(pvr://recordings/Big Bang)
19:42:15 T:3492 NOTICE: Thread Background Loader start, auto delete: false
19:42:15 T:3492 DEBUG: Thread Background Loader 3492 terminating
19:42:15 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:17 T:3780 DEBUG: Previous line repeats 3 times.
19:42:17 T:3780 DEBUG: Keyboard: scancode: 19, sym: 0070, unicode: 0070, modifier: 0
19:42:17 T:3780 DEBUG: CApplication::OnKey: p (f050) pressed, action is Play
19:42:17 T:3780 DEBUG: ------ Window Deinit (Pointer.xml) ------
19:42:17 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:20 T:3780 DEBUG: Previous line repeats 5 times.
19:42:20 T:3780 DEBUG: ------ Window Init (Pointer.xml) ------
19:42:20 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:26 T:3780 DEBUG: Previous line repeats 10 times.
19:42:26 T:3780 DEBUG: CApplication:TonguerocessMouse: trying mouse action leftclick
19:42:26 T:3780 DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(home)
19:42:26 T:3780 DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(home)
19:42:26 T:3780 DEBUG: Activating window ID: 10000
19:42:26 T:3780 DEBUG: ------ Window Deinit (MyPVR.xml) ------
19:42:26 T:3780 DEBUG: ------ Window Init (Home.xml) ------
19:42:26 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:30 T:3780 DEBUG: Previous line repeats 7 times.
19:42:30 T:3780 DEBUG: CApplication:TonguerocessMouse: trying mouse action leftclick
19:42:30 T:3780 DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(Settings)
19:42:30 T:3780 DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(Settings)
19:42:30 T:3780 DEBUG: Activating window ID: 10004
19:42:30 T:3780 DEBUG: ------ Window Deinit (Home.xml) ------
19:42:30 T:3780 DEBUG: ------ Window Init (Settings.xml) ------
19:42:30 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:32 T:3780 DEBUG: Previous line repeats 4 times.
19:42:32 T:3780 DEBUG: CApplication:TonguerocessMouse: trying mouse action leftclick
19:42:32 T:3780 DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(ServiceSettings)
19:42:32 T:3780 DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(ServiceSettings)
19:42:32 T:3780 DEBUG: Activating window ID: 10018
19:42:32 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:33 T:3780 DEBUG: ------ Window Deinit (Settings.xml) ------
19:42:33 T:3780 DEBUG: ------ Window Init (SettingsCategory.xml) ------
19:42:33 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:34 T:3780 DEBUG: CApplication:TonguerocessMouse: trying mouse action rightclick
19:42:34 T:3780 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
19:42:34 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:34 T:3780 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
19:42:34 T:3780 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
19:42:34 T:3780 DEBUG: ------ Window Init (Settings.xml) ------
19:42:35 T:3780 DEBUG: Previous line repeats 1 times.
19:42:35 T:3780 DEBUG: CApplication:TonguerocessMouse: trying mouse action leftclick
19:42:35 T:3780 DEBUG: CApplication::ExecuteXBMCAction : Translating ActivateWindow(SystemSettings)
19:42:35 T:3780 DEBUG: CApplication::ExecuteXBMCAction : To ActivateWindow(SystemSettings)
19:42:35 T:3780 DEBUG: Activating window ID: 10016
19:42:35 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:35 T:3780 DEBUG: ------ Window Deinit (Settings.xml) ------
19:42:35 T:3780 DEBUG: ------ Window Init (SettingsCategory.xml) ------
19:42:36 T:2488 DEBUG: NEWADDON PythonCallbackHandler construction with PyThreadState 0x7fe0ec8
19:42:38 T:3780 DEBUG: Previous line repeats 3 times.
19:42:38 T:3780 DEBUG: CApplication:TonguerocessMouse: trying mouse action leftclick
19:42:38 T:3780 NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:42:38 T:3780 NOTICE: Log level changed to 0
As an update, I have narrowed down the issue. It appears that I can record live tv and play the recording. The problem ocurrs when using a timer. If I manually start recording, the video is fine. If I set a timer to record a show, the video file (.ts) will not play. The size of the file is 0 KB. The timer is triggered because the file is created. It's like the automatic recording function doesn't work. Any ideas? Please?
I use Next PVR and don't have this issue. Having said that, I use the Next PVR software to schedule recordings rather than XBMC as it allows series recording etc. Have you tried it that way? Perhaps that would at least narrow down the issue to either/both/neither XBMC and/or Next PVR.
Also, try the Next PVR forums if you haven't already. GL.
