Hey,
I tried to configure VNSI (as well as xvdr) to use my debian vdr (e-tobi+oppserver-sources), which runs well as streamdev-server for vlc or iptv/mxplayer on android.
I got it running with OpenElec as well as raspbmc as far as it connects, load EPG and channels. Starting LiveTV takes very long, but that may be because of the raspberry......
But no channels shows up with a video....i got only sound.
I'm not able to find any fail-config neither some logging which helps (seems everything fine)....
My Env:
- OpenELEC 2.99 or raspbmc (newest) - with Codecs
- VNSI Plugin 1.6.4 from xbmc-channel
- Debian VDR 1.7.28, vnsi 0.9.1
I hope anyone can help and i do not need to build things myself (i'm too lazy)
soralanthanas
PS: xbmc on android shows up some video.....
I can't help as long you don't post any logs.
Syslog snippets on vdr:
Quote:Feb 26 20:49:15 merlin vdr: [13083] loading plugin: /usr/lib/vdr/plugins/libvdr-vnsiserver3.so.1.7.28
Feb 26 20:49:15 merlin vdr: [13083] initializing plugin: vnsiserver3 (0.9.1): VDR-Network-Streaming-Interface (VNSI) Server
Feb 26 20:49:15 merlin vdr: [13083] starting plugin: vnsiserver3
Feb 26 20:49:15 merlin vdr: [13083] VNSI: VNSI Server started
Feb 26 20:49:15 merlin vdr: [13083] VNSI: Channel streaming timeout: 10 seconds
Feb 26 20:49:15 merlin vdr: [13094] VDR VNSI Server thread started (pid=13083, tid=13094)
Feb 26 21:02:11 merlin vdr: [13094] loading /var/lib/vdr/plugins/vnsiserver3/allowed_hosts.conf
Feb 26 21:02:11 merlin vdr: [13094] VNSI: Client with ID 0 connected: 192.168.100.4:42398
Feb 26 21:02:11 merlin vdr: [13307] VNSI: Welcome client 'XBMC Media Center' with protocol version '3'
Feb 26 21:07:15 merlin vdr: [13094] VNSI: Recordings state changed (6)
Feb 26 21:20:24 merlin vdr: [13094] loading /var/lib/vdr/plugins/vnsiserver3/allowed_hosts.conf
Feb 26 21:20:24 merlin vdr: [13094] VNSI: Client with ID 1 connected: 192.168.100.4:43041
Feb 26 21:20:24 merlin vdr: [13611] VNSI: Welcome client 'XBMC Media Center' with protocol version '3'
Feb 26 21:20:24 merlin vdr: [13611] VNSI: Successfully switched to channel 1 - Das Erste
Feb 26 21:20:24 merlin vdr: [13611] VNSI: Started streaming of channel Das Erste (timeout 10 seconds)
Feb 26 21:20:26 merlin vdr: [13089] VNSI: Video Input - new pmt, attaching receiver
Feb 26 21:20:26 merlin vdr: [13614] VNSI: Created stream for pid=101 and type=7
Feb 26 21:20:26 merlin vdr: [13614] VNSI: Created stream for pid=102 and type=2
Feb 26 21:20:26 merlin vdr: [13614] VNSI: Created stream for pid=103 and type=2
Feb 26 21:20:26 merlin vdr: [13614] VNSI: Created stream for pid=106 and type=1
Feb 26 21:20:26 merlin vdr: [13614] VNSI: Created stream for pid=105 and type=9
Feb 26 21:20:26 merlin vdr: [13614] VNSI: Created stream for pid=104 and type=11
Feb 26 21:23:34 merlin vdr: [13611] VNSI-Error: cxSocket::read: read() error at 0/4
Feb 26 21:23:34 merlin vdr: [13614] VNSI: exit streamer thread
Feb 26 21:23:34 merlin vdr: [13094] VNSI: Client with ID 1 seems to be disconnected, removing from client list
Feb 26 21:25:00 merlin vdr: [13083] stopping plugin: vnsiserver3
Feb 26 21:25:00 merlin vdr: [13094] VDR VNSI Server thread ended (pid=13083, tid=13094)
Feb 26 21:25:10 merlin vdr: [13083] VNSI: VNSI Server stopped
Feb 26 21:25:19 merlin vdr: [13083] deleting plugin: vnsiserver3
Feb 26 21:25:32 merlin vdr: [13795] loading plugin: /usr/lib/vdr/plugins/libvdr-vnsiserver3.so.1.7.28
Feb 26 21:25:33 merlin vdr: [13795] initializing plugin: vnsiserver3 (0.9.1): VDR-Network-Streaming-Interface (VNSI) Server
Feb 26 21:25:33 merlin vdr: [13795] starting plugin: vnsiserver3
Feb 26 21:25:33 merlin vdr: [13795] VNSI: VNSI Server started
Feb 26 21:25:33 merlin vdr: [13795] VNSI: Channel streaming timeout: 10 seconds
Feb 26 21:25:33 merlin vdr: [13805] VDR VNSI Server thread started (pid=13795, tid=13805)
Feb 26 21:25:33 merlin vdr: [13805] loading /var/lib/vdr/plugins/vnsiserver3/allowed_hosts.conf
Feb 26 21:25:33 merlin vdr: [13805] VNSI: Client with ID 0 connected: 192.168.100.4:43071
Feb 26 21:25:33 merlin vdr: [13813] VNSI: Welcome client 'XBMC Media Center' with protocol version '3'
Feb 26 21:25:37 merlin vdr: [13805] loading /var/lib/vdr/plugins/vnsiserver3/allowed_hosts.conf
Feb 26 21:25:37 merlin vdr: [13805] VNSI: Client with ID 1 connected: 192.168.100.4:43072
Feb 26 21:25:37 merlin vdr: [13816] VNSI: Welcome client 'XBMC Media Center' with protocol version '3'
Feb 26 21:25:37 merlin vdr: [13816] VNSI: Successfully switched to channel 1 - Das Erste
Feb 26 21:25:37 merlin vdr: [13816] VNSI: Started streaming of channel Das Erste (timeout 10 seconds)
Feb 26 21:25:37 merlin vdr: [13801] VNSI: Video Input - new pmt, attaching receiver
Feb 26 21:25:37 merlin vdr: [13819] VNSI: Created stream for pid=101 and type=7
Feb 26 21:25:37 merlin vdr: [13819] VNSI: Created stream for pid=102 and type=2
Feb 26 21:25:37 merlin vdr: [13819] VNSI: Created stream for pid=103 and type=2
Feb 26 21:25:37 merlin vdr: [13819] VNSI: Created stream for pid=106 and type=1
Feb 26 21:25:37 merlin vdr: [13819] VNSI: Created stream for pid=105 and type=9
Feb 26 21:25:37 merlin vdr: [13819] VNSI: Created stream for pid=104 and type=11
Feb 26 21:25:58 merlin vdr: [13819] VNSI: exit streamer thread
Feb 26 21:25:58 merlin vdr: [13816] VNSI: Successfully switched to channel 2 - ZDF
Feb 26 21:25:58 merlin vdr: [13816] VNSI: Started streaming of channel ZDF (timeout 10 seconds)
Feb 26 21:25:58 merlin vdr: [13801] VNSI: Video Input - new pmt, attaching receiver
Feb 26 21:25:58 merlin vdr: [13826] VNSI: Created stream for pid=110 and type=7
Feb 26 21:25:58 merlin vdr: [13826] VNSI: Created stream for pid=120 and type=2
Feb 26 21:25:58 merlin vdr: [13826] VNSI: Created stream for pid=121 and type=2
Feb 26 21:25:58 merlin vdr: [13826] VNSI: Created stream for pid=122 and type=2
Feb 26 21:25:58 merlin vdr: [13826] VNSI: Created stream for pid=125 and type=1
Feb 26 21:25:58 merlin vdr: [13826] VNSI: Created stream for pid=131 and type=9
Feb 26 21:25:58 merlin vdr: [13826] VNSI: Created stream for pid=130 and type=11
Feb 26 21:35:21 merlin vdr: [13816] VNSI-Error: cxSocket::read: read() error at 0/4
Feb 26 21:35:21 merlin vdr: [13813] VNSI: cxSocket::read: eof, connection closed
Feb 26 21:35:21 merlin vdr: [13826] VNSI: exit streamer thread
Feb 26 21:35:21 merlin vdr: [13805] VNSI: Client with ID 0 seems to be disconnected, removing from client list
Feb 26 21:35:21 merlin vdr: [13805] VNSI: Client with ID 1 seems to be disconnected, removing from client list
Feb 26 21:38:04 merlin vdr: [13805] loading /var/lib/vdr/plugins/vnsiserver3/allowed_hosts.conf
Feb 26 21:38:04 merlin vdr: [13805] VNSI: Client with ID 2 connected: 192.168.100.4:33357
Feb 26 21:38:04 merlin vdr: [14045] VNSI: Welcome client 'XBMC Media Center' with protocol version '3'
Feb 26 21:38:04 merlin vdr: [14045] VNSI: cxSocket::read: eof, connection closed
Feb 26 21:38:04 merlin vdr: [13805] VNSI: Client with ID 2 seems to be disconnected, removing from client list
Feb 26 21:40:24 merlin vdr: [13805] loading /var/lib/vdr/plugins/vnsiserver3/allowed_hosts.conf
Feb 26 21:40:24 merlin vdr: [13805] VNSI: Client with ID 3 connected: 192.168.100.4:33363
Feb 26 21:40:24 merlin vdr: [14089] VNSI: Welcome client 'XBMC Media Center' with protocol version '3'
Feb 26 21:40:55 merlin vdr: [13805] VNSI: Recordings state changed (6)
Feb 26 21:44:30 merlin vdr: [13805] loading /var/lib/vdr/plugins/vnsiserver3/allowed_hosts.conf
Feb 26 21:44:30 merlin vdr: [13805] VNSI: Client with ID 4 connected: 192.168.100.4:33365
Feb 26 21:44:30 merlin vdr: [14146] VNSI: Welcome client 'XBMC Media Center' with protocol version '3'
Feb 26 21:44:30 merlin vdr: [14146] VNSI: Successfully switched to channel 60 - hr3
Feb 26 21:44:30 merlin vdr: [14146] VNSI: Started streaming of channel hr3 (timeout 10 seconds)
Feb 26 21:44:31 merlin vdr: [13801] VNSI: Video Input - new pmt, attaching receiver
Feb 26 21:44:31 merlin vdr: [14149] VNSI: Created stream for pid=421 and type=2
Feb 26 21:45:02 merlin vdr: [14146] VNSI-Error: cxSocket::read: read() error at 0/4
Feb 26 21:45:02 merlin vdr: [14149] VNSI: exit streamer thread
Feb 26 21:45:02 merlin vdr: [13805] VNSI: Client with ID 4 seems to be disconnected, removing from client list
Feb 26 21:45:03 merlin vdr: [13805] loading /var/lib/vdr/plugins/vnsiserver3/allowed_hosts.conf
Feb 26 21:45:03 merlin vdr: [13805] VNSI: Client with ID 5 connected: 192.168.100.4:33366
Feb 26 21:45:03 merlin vdr: [14166] VNSI: Welcome client 'XBMC Media Center' with protocol version '3'
Feb 26 21:45:03 merlin vdr: [14166] VNSI: Successfully switched to channel 1 - Das Erste
Feb 26 21:45:03 merlin vdr: [14166] VNSI: Started streaming of channel Das Erste (timeout 10 seconds)
Feb 26 21:45:04 merlin vdr: [13801] VNSI: Video Input - new pmt, attaching receiver
Feb 26 21:45:04 merlin vdr: [14169] VNSI: Created stream for pid=101 and type=7
Feb 26 21:45:04 merlin vdr: [14169] VNSI: Created stream for pid=102 and type=2
Feb 26 21:45:04 merlin vdr: [14169] VNSI: Created stream for pid=103 and type=2
Feb 26 21:45:04 merlin vdr: [14169] VNSI: Created stream for pid=106 and type=1
Feb 26 21:45:04 merlin vdr: [14169] VNSI: Created stream for pid=105 and type=9
Feb 26 21:45:04 merlin vdr: [14169] VNSI: Created stream for pid=104 and type=11
Feb 26 22:02:48 merlin vdr: [13805] loading /var/lib/vdr/plugins/vnsiserver3/allowed_hosts.conf
Feb 26 22:02:48 merlin vdr: [13805] VNSI: Client with ID 6 connected: 192.168.100.109:45707
Feb 26 22:02:48 merlin vdr: [14451] VNSI: Welcome client 'XBMC Media Center' with protocol version '3'
Feb 26 22:03:00 merlin vdr: [13805] VNSI: Recordings state changed (9)
Feb 26 22:04:30 merlin vdr: [13805] loading /var/lib/vdr/plugins/vnsiserver3/allowed_hosts.conf
Feb 26 22:04:30 merlin vdr: [13805] VNSI: Client with ID 7 connected: 192.168.100.109:45708
Feb 26 22:04:30 merlin vdr: [14470] VNSI: Welcome client 'XBMC Media Center' with protocol version '3'
Feb 26 22:04:30 merlin vdr: [14470] VNSI: Successfully switched to channel 1 - Das Erste
Feb 26 22:04:30 merlin vdr: [14470] VNSI: Started streaming of channel Das Erste (timeout 10 seconds)
Feb 26 22:04:31 merlin vdr: [13801] VNSI: Video Input - new pmt, attaching receiver
Feb 26 22:04:31 merlin vdr: [14472] VNSI: Created stream for pid=101 and type=7
Feb 26 22:04:31 merlin vdr: [14472] VNSI: Created stream for pid=102 and type=2
Feb 26 22:04:31 merlin vdr: [14472] VNSI: Created stream for pid=103 and type=2
Feb 26 22:04:31 merlin vdr: [14472] VNSI: Created stream for pid=106 and type=1
Feb 26 22:04:31 merlin vdr: [14472] VNSI: Created stream for pid=105 and type=9
Feb 26 22:04:31 merlin vdr: [14472] VNSI: Created stream for pid=104 and type=11
Feb 26 22:06:15 merlin vdr: [14169] VNSI-Error: cxSocket::write: write() error
Feb 26 22:06:15 merlin vdr: [14166] VNSI: cxSocket::read: eof, connection closed
Feb 26 22:06:15 merlin vdr: [14169] VNSI: exit streamer thread
Feb 26 22:06:15 merlin vdr: [13805] VNSI: Client with ID 5 seems to be disconnected, removing from client list
Feb 26 22:06:16 merlin vdr: [14472] VNSI-Error: cxSocket::write: write() error
Feb 26 22:06:16 merlin vdr: [14470] VNSI: cxSocket::read: eof, connection closed
Feb 26 22:06:16 merlin vdr: [14472] VNSI: exit streamer thread
Feb 26 22:06:16 merlin vdr: [13805] VNSI: Client with ID 7 seems to be disconnected, removing from client list
a lot of the these messages
Quote:Feb 26 21:02:15 merlin vdr: [13094] VNSI: Requesting clients to reload channel list
some of them:
Quote:Feb 26 21:09:08 merlin vdr: [13094] VNSI: Trigger EPG update for channel COSMOPOLITAN
Ah ok...some errors found.....after removing the tomatos from my eyes....
Quote:21:44:19 T:2732586048 NOTICE: Thread PVR Channel Window start, auto delete: false
21:44:29 T:3038081024 NOTICE: Previous line repeats 1 times.
21:44:29 T:3038081024 NOTICE: COMXPlayer: Opening: pvr://channels/radio/Alle Radio-Kan<C3><A4>le/2.pvr
21:44:30 T:2710361152 NOTICE: Thread COMXPlayer start, auto delete: false
21:44:30 T:2710361152 NOTICE: Creating InputStream
21:44:30 T:2710361152 NOTICE: AddOnLog: VDR VNSI Client: Logged in at '1361911470+3600' to 'VDR-Network-Streaming-Interface (VNSI) Server' Version: '0.9.1' with protocol version '3'
21:44:33 T:2710361152 NOTICE: Creating Demuxer
21:44:34 T:2710361152 WARNING: CDVDMessageQueue(audio):ut MSGQ_NOT_INITIALIZED
21:44:34 T:2710361152 WARNING: CDVDMessageQueue(video):ut MSGQ_NOT_INITIALIZED
21:44:34 T:2710361152 NOTICE: Opening audio stream: 0 source: 256
21:44:35 T:2710361152 NOTICE: Creating audio thread
21:44:35 T:2691433536 NOTICE: Thread COMXPlayerAudio start, auto delete: false
21:44:35 T:2710361152 NOTICE: Opening audio stream: 0 source: 256
21:44:35 T:2691433536 NOTICE: OMXClock using audio as reference
21:45:02 T:2710361152 NOTICE: COMXPlayer::OnExit()
21:45:02 T:2710361152 NOTICE: OMXPlayer: closing audio stream
21:45:02 T:2710361152 NOTICE: Closing audio stream
21:45:02 T:2691433536 NOTICE: thread end: OMXPlayerAudio::OnExit()
21:45:02 T:2710361152 NOTICE: OMXClock using video as reference
21:45:02 T:2710361152 NOTICE: COMXPlayer::OnExit() deleting demuxer
21:45:02 T:2710361152 NOTICE: COMXPlayer::OnExit() deleting input stream
21:45:03 T:3038081024 NOTICE: OMXClock using video as reference
21:45:03 T:3038081024 NOTICE: Previous line repeats 1 times.
21:45:03 T:3038081024 NOTICE: COMXPlayer: Opening: pvr://channels/tv/Alle TV-Kan<C3><A4>le/0.pvr
21:45:03 T:2710361152 NOTICE: Thread COMXPlayer start, auto delete: false
21:45:03 T:2710361152 NOTICE: Creating InputStream
21:45:03 T:2710361152 NOTICE: AddOnLog: VDR VNSI Client: Logged in at '1361911503+3600' to 'VDR-Network-Streaming-Interface (VNSI) Server' Version: '0.9.1' with protocol version '3'
21:45:04 T:2710361152 NOTICE: Creating Demuxer
21:45:04 T:2710361152 WARNING: CDVDMessageQueue(audio):ut MSGQ_NOT_INITIALIZED
21:45:04 T:2710361152 WARNING: CDVDMessageQueue(video):ut MSGQ_NOT_INITIALIZED
21:45:04 T:2710361152 NOTICE: Opening video stream: 0 source: 256
21:45:05 T:2976912448 ERROR: COMXCoreComponent:ecoderEventHandler OMX.broadcom.video_decode - OMX_ErrorUnsupportedSetting, unsupported setting
21:45:05 T:2710361152 ERROR: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.video_decode) - OMX_UseBuffer failed with omx_err(0x80001018)
21:45:05 T:2710361152 ERROR: COMXVideo::Open AllocOMXInputBuffers error (080001018)
21:45:05 T:2710361152 ERROR: OMXPlayerVideo : Error open video output
21:45:05 T:2710361152 NOTICE: OMXClock using video as reference
21:45:05 T:2710361152 WARNING: OpenVideoStream - Unsupported stream 0. Stream disabled.
21:45:05 T:2710361152 NOTICE: Opening audio stream: 1 source: 256
21:45:05 T:2710361152 NOTICE: Creating audio thread
21:45:05 T:2691433536 NOTICE: Thread COMXPlayerAudio start, auto delete: false
21:45:05 T:2710361152 NOTICE: Opening Subtitle stream: 4 source: 256
21:45:05 T:2710361152 NOTICE: Opening video stream: 0 source: 256
soralanthanas
please don't post fragments of log in this forum. Always post full logs to xbmclogs.com and provide the links here.
I am wondering if you have properly installed the license for the MPEG2 codec on the pi.
Uh-oh !
I'm sorry, didn't know.
here we go:
http://www.xbmclogs.com/show.php?id=1270
I installed the mpeg2 license via raspbmc gui and it's been update by gui into config.txt...
vdr-serverlog is too much to give away ....
