2013-02-27, 17:55
2013-03-29, 21:22
Very much thanks for your work on this table tennis channel!
Unfortunately it does not work on my raspbmc: Sound is playing but no picture. What can it be?
2013-03-30, 14:33
It seems that XBMC doesn't support the codec, my add-on is working fine. Ask in the raspberry pi section for support.
2013-05-16, 13:48
seems there is something maybe broken with the live stream at least (rest seems to work) , anyone else with problems ?
13:20:18 T:2842688320 NOTICE: -->Python Interpreter Initialized<--
13:20:19 T:2842688320 NOTICE: Mode: 4
13:20:19 T:2842688320 NOTICE: URL: http://streamaccess.unas.tv/flash/24/119...rtnerid=24
13:20:19 T:2842688320 NOTICE: Name: LIVE: LIEBHERR 2013 World Table Tennis Championships Paris TABLE1 - GROTH Jonathan DEN/STERNBERG Kasper DEN vs GAUZY Simon FRA/LEBESSON Emmanuel FRA
13:20:19 T:2842688320 NOTICE: Thumbnail: http://streamaccess.unas.tv/flash/ittf/i...come_2.jpg
13:20:19 T:2842688320 NOTICE: http://streamaccess.unas.tv/flash/24/119...rtnerid=24
13:20:19 T:2842688320 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.NameError'>
Error Contents: global name 'debug' is not defined
File "/home/justme/.xbmc/addons/plugin.video.ittv/default.py", line 1309, in <module>
PLAY_LIVE(url,name)
File "/home/justme/.xbmc/addons/plugin.video.ittv/default.py", line 168, in PLAY_LIVE
log('auth: "'+auth+'"')
File "/home/justme/.xbmc/addons/plugin.video.ittv/default.py", line 1216, in log
if debug == '1':
NameError: global name 'debug' is not defined
13:20:19 T:3007080256 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.ittv/?url=http%3A%2F%2Fstreamaccess.unas.tv%2Fflash%2F24%2F119862.xml%3Fstreamid%3D119862%2526partnerid%3D24&mode=4&thumb=http%3A%2F%2Fstreamaccess.unas.tv%2Fflash%2Fittf%2FitTV_welcome_2.jpg&name=LIVE%3A+LIEBHERR+2013+World+Table+Tennis+Championships+Paris+TABLE1+-+GROTH+Jonathan+DEN%2FSTERNBERG+Kasper+DEN+vs+GAUZY+Simon+FRA%2FLEBESSON+Emmanuel+FRA]
13:20:19 T:2842688320 NOTICE: Thread BackgroundLoader start, auto delete: false
13:20:23 T:2842688320 NOTICE: Thread XBPython start, auto delete: false
PLAY_LIVE(url,name)
if debug == '1':
2013-05-17, 10:03
Please use next time when posting parts of the log.
Livestreams are not implemented right now - the add-on can't create a valid video url (maybe some cookie trickery is involved, idk). I will hide them in the next revision. You can watch recorded matches instead.
the code tags (the hashtag in the editor)
2013-06-03, 02:34
membrane,
Thank you for the update for ittv. I confirmed that my issues has been fixed. The only minor thing is that it lists the video entries twice. In Liebherr Paris in the World event, When I scroll down the list of videos, it repeats the same list twice. But, practically, it is not an issue at all.
Thank you.
Thank you.
2013-06-03, 09:19
The website is difficult to scrape, I have to improve the regex patterns. I did not notice the error because of the many videos/path options.
But this will have to wait. I'm very busy because of my studies.
2013-06-08, 04:27
membrane,
That is not a big issue.
By the way, Live feed is currently available (depending on the time).
If you can find time to play with it, please investigate to see if you can add it back.
Thank you.
Thank you.
2016-07-15, 06:02
Hello, I installed your repo but could not find the addon.
Is there a chance to include it again?
Sent from my SM-G925I
2016-07-23, 22:45
Yeah, it went down with google code. I will upload the add-on if it is in working condition, but I'm a bit sceptic about that.
2016-07-24, 12:42
I'm also looking forward for it. Good luck!
2016-08-14, 15:28
FYI, the old add-on won't play the videos. If someone wants to pick up my work I will upload it on Github. I suspect that there has been a change in the laola1.tv backend.
