Full Version: iPad mini play MKV often Dropped frames....
General
Unique ID : 230021745995621518875077133100864729479 (0xAD0C93AC4417260EAA5766A2A5037187)
Complete name : H:\1969..Easy.Rider\.Easy.Rider.1969.BDRip.X264.iNT-TLF(E2F8BEAE).mkv
Format : Matroska
Format version : Version 2
File size : 1.37 GiB
Duration : 1h 35mn
Overall bit rate : 2 047 Kbps
Encoded date : UTC 2009-09-16 04:37:59
Writing application : mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 35mn
Bit rate : 1 597 Kbps
Width : 1 056 pixels
Height : 576 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.110
Stream size : 1.04 GiB (76%)
Writing library : x264 core 75 r1251M e553a4c
Encoding settings : cabac=1 / ref=16 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=8 / nr=0 / decimate=0 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / mbtree=0 / bitrate=1597 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Default : No
Forced : No
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 1h 35mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 306 MiB (22%)
Language : English
Default : Yes
Forced : No
The video is up
ios 6.1.2
XBMC 12
often Dropped frames(The picture become slow,it last a little little time,but often....)
Can developers Solve the problem?
16 ref frames has given us problems with the hardware decoder. Try a differen file Wink
(2013-02-28, 19:46)Eliah Wrote: [ -> ]16 ref frames has given us problems with the hardware decoder. Try a differen file Wink
What's wrong with 16 ref frames?
I don't know,can you explain it ?
