2013-03-01, 20:04
I install Xbmcbuntu (AMD-Version) on my HTPC. Installation went fine, no errors accured.
The pc boots with out any problemes until the background of the default skin becomes visible. Then XBMC crashes and restarts automatically. The repeats three times and then the screen shows the login page for the desktop.
The same happens when I use the "live-usb-version"
In the latest logfile I cant find any obvious error. Anyone got an idea what might cause this behaviour?
Regards,
Monchi
P.s.: The PC is running on an AMD Athlon X2 BE with an dedicated graficcard (Radeon HD 4450)
Regards,
Monchi
