(2019-11-16, 08:00)IT007 Wrote: [ -> ]Thanks, looks a bit cleaner that what I came up with. I use logitech harmony and needed this for the power off command to stop kodi playback before exiting.
No problem. I also use a Logitech Harmony for controlling Kodi, etc.
(2018-09-23, 19:48)iophobia Wrote: [ -> ]Don't know where to put this but hope somebody can help.
As of Kodi 17 I used to invoke Alexa --> IFTTT --> Kodi JSON-RPC to change PVR channels in Kodi via HTTP GET and "http://URL/jsonrpc?request={ "jsonrpc": "2.0", "method": "Player.Open", "params": { "item": { "channelid": 5} }, "id": 3 }" which worked liked a charme. I understand that the API changes in v18 don't allow for "GET" but I simply have no idea how a working example for the v18 API would look like for my case.
Thanks in advance.
Anybody managed to get Player.Open to work via IFTTT in Kodi 18? I don't wanna mess around with (my)OpenHAB implementations or such if it can be done in an easier way that already worked in v17.
(2019-12-18, 15:41)iophobia Wrote: [ -> ] (2018-09-23, 19:48)iophobia Wrote: [ -> ]Don't know where to put this but hope somebody can help.
Thanks in advance.
I also have the same exact issue. It's one of the reasons why I haven't upgraded to Kodi 18. I use
Cortana --> IFTTT --> EventGhost --> Kodi JSON-RPC on Kodi 17.6 (DSPlayer build). If you (or anyone) figures it out, PLEASE post here. I will also do the same.
how to shutdown kodi using request from external server?
when was a normal version of kodi I used this url
Quote:getURL('http://192.168.1.12:8080/jsonrpc?request={"jsonrpc":"2.0","method":"System.Shutdown","id":1}');
Can anyone give me a working example of subscribing to notifications?
When I pass this:
json:
{"jsonrpc": "2.0", "method": "Configuration.Notifications", "id": 1}
I get this:
json:
{"error":{"code":-32601,"message":"Method not found."},"id":1,"jsonrpc":"2.0"}
(2020-05-22, 05:20)madkat Wrote: [ -> ]Can anyone give me a working example of subscribing to notifications?
When I pass this:
json:
I get this:
json:
Scratch that, I'm getting somewhere now:
json:
{"jsonrpc": "2.0", "method": "JSONRPC.SetConfiguration", "params": {"Configuration.Notifications": { "PVR": true, "Player": true }}, "id": 1}
(2020-05-22, 05:25)madkat Wrote: [ -> ] (2020-05-22, 05:20)madkat Wrote: [ -> ]Can anyone give me a working example of subscribing to notifications?
When I pass this:
json:
I get this:
json:
json:
I'm not seeing any notifications though...? (Connected via TCP)
(2020-05-22, 14:24)madkat Wrote: [ -> ] (2020-05-22, 05:25)madkat Wrote: [ -> ] (2020-05-22, 05:20)madkat Wrote: [ -> ]Can anyone give me a working example of subscribing to notifications?
When I pass this:
json:
I get this:
json:
json:
I am seeing notifications - e.g. play/pause.
New problem with Live TV: I pass this method invocation:
json:
{"jsonrpc": "2.0", "method": "Player.GetProperties", "params":{"playerid":1,"properties":["totaltime","time"]}, "id": 1}
And I get back a perfectly sensible reply:
json:
{"id":1,"jsonrpc":"2.0","result":{"time":{"hours":0,"milliseconds":0,"minutes":40,"seconds":11},"totaltime":{"hours":1,"milliseconds":
0,"minutes":0,"seconds":0}}}
However, the "time" is the time of the stream, not the time of the playing programme - if I pause, the "time" returned continues to increase. Do I need to do something with the PVR to get the state information I'm looking for?
I would like to launch a addon from a remote server.
i found this but didn't work, can you show me a example how to launch a addon ?
,%22id%22:%221%22}]
(2020-07-24, 19:45)karlzre Wrote: [ -> ]Hi,
,%22id%22:%221%22}]
Your message doesn't display properly. Are you on a Mac? I'm asking due to all the "%22" references in your URL. They should be spaces.
You must send a RESTful command to your Kodi's HTTP server address. IIRC, Kodi 16 and earlier requires a GET command. Kodi 17+ uses POST.
Instructions using command line/CURL/BaSH formatting found
here.
Can any one tell me if its possible to combine these into one command,
{"jsonrpc": "2.0", "method": "Player.GetProperties", "params": { "properties": ["currentaudiostream", "percentage", "totaltime", "speed"], "playerid": 1 }, "id": "VideoGetItem"}
and
{"jsonrpc": "2.0", "method": "Player.GetItem", "params": { "properties": ["title", "thumbnail"], "playerid": 1 }, "id": "1"}
thanks
(2020-08-02, 06:33)mpg732 Wrote: [ -> ]Can any one tell me if its possible to combine these into one command,
and
thanks
Sry, that's not possible.
Sorry for
cross-posting....Mods, please feel free to delete my original post. This thread seems more relevant than the one where I posted originally.
Onward....
I run my own self hosted web page where I admin many of my home server items. While not an expert, for years I muddled through figuring out how to do things. I created this page in php. One of the many things I was able to do, were Video and Music
Library Updates.
Leia simply killed this feature (and others). I did not realize this until I upgraded from Krypton.
Without luck, I have tried for many many hours, to execute the curl command that performs this action in
PHP:
curl --data-binary '{ "jsonrpc": "2.0", "method": "VideoLibrary.Scan", "id": "mybash"}' -H 'content-type: application/json;' http://kodi:[email protected]:80/jsonrpc
Would some kind soul please guide me to make php execute the above curl command... every sample I have seen includes "options, arrays, things" that I cannot relate to the line above. Figuring this out will allow me to also update a few other bits that my page did.
I have grown accustomed executing many Kodi commands with the old API method. I have Kodi on a couple of Intel NUC's running LibreElec.
Thank you in advance.
H.
Answering my own question above.... I would have NEVER figured this out until I ran into a web site that does Curl to PHO conversion.
https://incarnate.github.io/curl-to-php/
I entered:
and it output this:
php:
// Generated by curl-to-PHP: http://incarnate.github.io/curl-to-php/
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, 'http://kodi:[email protected]:80/jsonrpc');
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, "{ \"jsonrpc\": \"2.0\", \"method\": \"VideoLibrary.Scan\", \"params\":{\"directory\":\"smb://TOWER/Media/Music Shows/\"}, \"id\": \"mybash\"}");
$headers = array();
$headers[] = 'Content-Type: application/json;';
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
$result = curl_exec($ch);
if (curl_errno($ch)) {
echo 'Error:' . curl_error($ch);
curl_close($ch);
It works like a charm... I was able to tweak things to adapt to my needs.
I hope this helps someone. I found that site purely by luck.
Thanks,
H.
(2020-08-09, 02:12)hernandito Wrote: [ -> ]and it output this:
Did you know that this forum has color-syntax support?
