2013-03-02, 22:29
UPDATE: found a workaround, I put in /etc/fstab
Now media is mounted automatically upon insertion and XBMC (although not playing that automatically) is able to browse DVD and play. I'd like to hear if anybody knows if this limitation would be removed in future XBMC versions.
Original post:
Hello, I burned a video file over a DVD+R that had a bootable session already, hiding the files from the first session. Now I ended up with a multi-session DVD with only one file in all iso9660, RR and joliet file-systems. I have verified that. Unfortunately putting the disk into the XBMC box (a fedora 18 install) it does not play. I see in the log it trying to play files that were available only in first session. See at bottom.
So am I correct in thinking XBMC sees only first session? Now this DVD is not a big deal because I can burn a fresh one. But I'm used to append DVDs with new data from camera and copying to disk, then burn again a fresh DVD is a PITA. Old media too. I see in a wiki page [1] that this is a known limitation of XBMC.
Are there any plans to remove that limitation? Any workaround?
[1] http://everything.explained.at/XBMC/
/dev/cdrom /media/cdrom udf,iso9660 user,auto,exec,utf8 0 0
Original post:
22:21:18 T:2982890304 ERROR: udf25::UDFReadBlocksRaw - Can't seek to block 256 (got 0)
22:21:18 T:2982890304 ERROR: Error on dvdnav_open
22:21:18 T:2982890304 ERROR: CDVDPlayer::OpenInputStream - error opening [iso9660://images/efiboot.img]
22:21:18 T:2982890304 NOTICE: CDVDPlayer::OnExit()
22:21:18 T:2982890304 NOTICE: CDVDPlayer::OnExit() deleting input stream
22:21:18 T:3078010752 ERROR: Playlist Player: skipping unplayable item: 0, path [iso9660://images/efiboot.img]
22:21:18 T:3078010752 NOTICE: DVDPlayer: Opening: iso9660://images/efidisk.img
22:21:18 T:3078010752 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
22:21:18 T:2982890304 NOTICE: Thread CDVDPlayer start, auto delete: false
22:21:18 T:2982890304 NOTICE: Creating InputStream
22:21:18 T:2982890304 ERROR: CDVDPlayer::OpenInputStream - error opening [iso9660://images/efidisk.img]
22:21:18 T:3078010752 ERROR: Playlist Player: skipping unplayable item: 1, path [iso9660://images/efidisk.img]
22:21:18 T:3078010752 NOTICE: DVDPlayer: Opening: iso9660://images/install.img
22:21:18 T:2982890304 ERROR: CDVDPlayer::OpenInputStream - error opening [iso9660://images/install.img]
22:21:18 T:3078010752 ERROR: Playlist Player: skipping unplayable item: 2, path [iso9660://images/install.img]
22:21:18 T:3078010752 NOTICE: DVDPlayer: Opening: iso9660://images/product.img
22:21:18 T:2982890304 ERROR: CDVDPlayer::OpenInputStream - error opening [iso9660://images/product.img]
