2013-03-03, 18:55
Hey all,
I have been using XBMC for a little over a year now. Throughout that time i have suffered issues with my libraries corrupting somehow.
The two most common issues are one of my libraries becoming empty, and needing a full rebuild.
I also often have the libraries just refuse to update, but let's focus on the first issue for now.
Usually to resolve this, i just rename the sql lite .db file and scan my folders back into the library. Bit of a pain.
I have actually saved my Music database file after the last corruption, opening this file in sql lite browser shows most of the data seems to be missing, but when viewed in a hex editor you can see the file hasnt been truncated and everything seems to be present. See: http://enpts.com/files/MyMusic32.zip
Can anyone please help as it's becoming a regular pain in the arse on an otherwise excellent system.
More info:
These issues have persisted throughout windows reinstalls, xbmc versions and hard drives (+ SSDs)
Nothing particually weird about my setup
- Windows 7 64bit
- XBMC12
- Library auto-update plugin, set to run every 4 hours
- Libraries set to clean every day
- Library update set to run on open, but usually i just hibernate the box anyway
Music
- single share on server 2008 r2 server, addressed via unc path (\\srv\MP3)
Movies
- two shares on server 2008 r2 server, addressed via unc paths (\\srv\Movies + \\srv\Temp Movies)
TV
- one share on server 2008 r2 server, addressed via unc path (\\srv\Media)
Any help appreciated! Thanks
More info:
- Windows 7 64bit
- XBMC12
Music
Movies
TV
