Full Version: Setting up environment - several errors.
Are these Wiki articles accurate for Frodo?
http://wiki.xbmc.org/index.php?title=HOW...or_Windows
http://wiki.xbmc.org/index.php?title=HOW..._using_Git
My environment is:
Windows 7 Pro x86
MS Visual C++ 2010 Express
Microsoft DirectX SDK June 2010
Java JRE 1.7.0.15 (needed for what?)
Having some problem setting it all up, first problem is when I run buildmingwlibs.bat, there is a problem with building xbmc_asap.dll.
##### building asap dlls #####
Makefile:179: warning: overriding commands for target `clean'
../players/Makefile:31: warning: ignoring old commands for target `clean'
cl -nologo -O2 -GL -GR- -W3 -DNDEBUG -Fexbmc_asap.dll -I. -I.. -Fo../xbmc/ -LD -MD ../xbmc/xbmc_asap.c ../asap.c ../acpu.c ../apokeysnd.c ../xbmc/xbmc_asap.res -link -release
xbmc_asap.c
../xbmc/xbmc_asap.c(48) : warning C4996: 'fopen': This function or variable may be unsafe. Consider using fopen_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
        C:\Program Files\Microsoft Visual Studio 10.0\VC\INCLUDE\stdio.h(234) : see declaration of 'fopen'
../xbmc/xbmc_asap.c(119) : warning C4996: 'strcpy': This function or variable may be unsafe. Consider using strcpy_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
../xbmc/xbmc_asap.c(120) : warning C4996: 'strcpy': This function or variable may be unsafe. Consider using strcpy_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
asap.c
../asap.c(1804) : warning C4996: 'strcpy': This function or variable may be unsafe. Consider using strcpy_s instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. See online help for details.
acpu.c
apokeysnd.c
   Creating library xbmc_asap.lib and object xbmc_asap.exp
Generating code
Finished generating code
LINK : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt
make: *** [xbmc_asap.dll] Error 2
cp: cannot stat `xbmc_asap.dll': No such file or directory
failed to compile /xbmc/system/players/paplayer/xbmc_asap.dll
I've solved it for the moment with copying it from an installed XBMC Frodo.
But after that when I try to build an untouched Frodo it fails with a couple of LINK : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt.
1>------ Skipped Build: Project: gtest, Configuration: Debug Win32 ------
1>Project not selected to build for this solution configuration
2>------ Build started: Project: libPlatinum, Configuration: Debug Win32 ------
3>------ Build started: Project: visDirectxSpectrum, Configuration: Debug (DirectX) Win32 ------
2>  libPlatinum.vcxproj -> D:\Source\Frodo_Base\project\VS2010Express\libs\libPlatinum\Debug\libPlatinumd.lib
3>     Creating library D:\Source\Frodo_Base\project\VS2010Express\libs\visDirectxSpectrum\Debug (DirectX)\Spectrum_win32dx.lib and object D:\Source\Frodo_Base\project\VS2010Express\libs\visDirectxSpectrum\Debug (DirectX)\Spectrum_win32dx.exp
3>LINK : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt
4>------ Build started: Project: visWaveform, Configuration: Debug (DirectX) Win32 ------
5>------ Build started: Project: ImageLib_dll, Configuration: Debug Win32 ------
4>     Creating library D:\Source\Frodo_Base\project\VS2010Express\libs\visWaveform\Debug (DirectX)\Waveform.lib and object D:\Source\Frodo_Base\project\VS2010Express\libs\visWaveform\Debug (DirectX)\Waveform.exp
4>LINK : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt
6>------ Build started: Project: cpluff, Configuration: Debug Win32 ------
6>     Creating library D:\Source\Frodo_Base\project\VS2010Express\libs\cpluff\Debug\cpluff.lib and object D:\Source\Frodo_Base\project\VS2010Express\libs\cpluff\Debug\cpluff.exp
6>LINK : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt
7>------ Build started: Project: libhdhomerun_dll, Configuration: Debug Win32 ------
5>     Creating library Debug\vs2010\cximagecrtd.lib and object Debug\vs2010\cximagecrtd.exp
5>LINK : warning LNK4098: defaultlib 'LIBCMTD' conflicts with use of other libs; use /NODEFAULTLIB:library
5>LINK : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt
7>     Creating library D:\Source\Frodo_Base\project\VS2010Express\libs\libhdhomerun_dll\Debug\hdhomerun.lib and object D:\Source\Frodo_Base\project\VS2010Express\libs\libhdhomerun_dll\Debug\hdhomerun.exp
7>LINK : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt
8>------ Build started: Project: visMilkdrop, Configuration: Debug Win32 ------
8>     Creating library D:\Source\Frodo_Base\project\VS2010Express\libs\visMilkdrop\Debug\Plugin.lib and object D:\Source\Frodo_Base\project\VS2010Express\libs\visMilkdrop\Debug\Plugin.exp
8>LINK : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt
9>------ Build started: Project: libass_dll, Configuration: Debug Win32 ------
9>     Creating library Debug\vs2010\libass_win32.lib and object Debug\vs2010\libass_win32.exp
9>LINK : warning LNK4098: defaultlib 'MSVCRT' conflicts with use of other libs; use /NODEFAULTLIB:library
9>LINK : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt
10>------ Build started: Project: XBMC, Configuration: Debug (DirectX) Win32 ------
10>  AddonModuleXbmc.cpp
10>  AddonModuleXbmcaddon.cpp
10>  AddonModuleXbmcgui.cpp
10>  AddonModuleXbmcplugin.cpp
10>  AddonModuleXbmcvfs.cpp
10>LINK : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt
========== Build: 1 succeeded, 8 failed, 29 up-to-date, 1 skipped ==========
Anyone having any suggestions/solutions?
Do you have sp1 for vs2010 installed (comes with windows update)? If yes try to reinstall it.
See more infos here:
http://stackoverflow.com/questions/10888...valid-or-c
http://social.msdn.microsoft.com/Forums/...787f1b359/
Anybody know why I suddenly have these errors?
C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\CL.exe /c /I..\..\ /I..\..\xbmc\ /I..\..\xbmc\cores\dvdplayer /I..\..\xbmc\win32 /I..\..\lib /I..\..\lib\ffmpeg /I"..\..\lib\ffmpeg\include-xbmc-win32" /I..\..\lib\libUPnP\Platinum\Source\Devices\MediaRenderer /I..\..\lib\libUPnP\Platinum\Source\Devices\MediaConnect /I..\..\lib\libUPnP\Platinum\Source\Devices\MediaServer /I..\..\lib\libUPnP\Platinum\Source\Platinum /I..\..\lib\libUPnP\Platinum\Source\Core /I..\..\lib\libUPnP\Platinum\Source\Extras /I..\..\lib\libUPnP\Neptune\Source\Core /I..\..\lib\libUPnP\Neptune\Source\System\Win32 /I..\..\lib\win32\pcre /I..\..\lib\win32 /I..\..\xbmc\cores\AudioEngine\ /Zi /nologo /W3 /WX- /MP /Ox /Ot /Oy /D TARGET_WINDOWS /D _WINDOWS /D _MSVC /D WIN32 /D NDEBUG /D _WIN32_WINNT=0x0501 /D NTDDI_VERSION=0x05010300 /D NOMINMAX /D _USE_32BIT_TIME_T /D HAS_DX /D __STDC_CONSTANT_MACROS /D TAGLIB_STATIC /D _VC80_UPGRADE=0x0710 /D _MBCS /GF- /Gm- /EHa /MT /GS /Gy- /arch:SSE /fp:precise /Zc:wchar_t /Zc:forScope /Yu"pch.h" /Fp"XBMC\Release (DirectX)\objs\XBMC.pch" /Fo"XBMC\Release (DirectX)\objs\\a\a\..\..\xbmc\interfaces\python\generated\\" /Fd"XBMC\Release (DirectX)\objs\vc100.pdb" /Gd /TP /wd4996 /FIpch.h /analyze- /errorReport:prompt ..\..\xbmc\interfaces\python\generated\AddonModuleXbmc.cpp ..\..\xbmc\interfaces\python\generated\AddonModuleXbmcaddon.cpp ..\..\xbmc\interfaces\python\generated\AddonModuleXbmcgui.cpp ..\..\xbmc\interfaces\python\generated\AddonModuleXbmcplugin.cpp ..\..\xbmc\interfaces\python\generated\AddonModuleXbmcvfs.cpp /MP
         AddonModuleXbmc.cpp
     1>c1xx : fatal error C1083: Cannot open source file: '..\..\xbmc\interfaces\python\generated\AddonModuleXbmc.cpp': No such file or directory
     1>c1xx : fatal error C1083: Cannot open source file: '..\..\xbmc\interfaces\python\generated\AddonModuleXbmcplugin.cpp': No such file or directory
     1>c1xx : fatal error C1083: Cannot open source file: '..\..\xbmc\interfaces\python\generated\AddonModuleXbmcaddon.cpp': No such file or directory
     1>c1xx : fatal error C1083: Cannot open source file: '..\..\xbmc\interfaces\python\generated\AddonModuleXbmcgui.cpp': No such file or directory
     1>c1xx : fatal error C1083: Cannot open source file: '..\..\xbmc\interfaces\python\generated\AddonModuleXbmcvfs.cpp': No such file or directory
     1>Done Building Project "C:\Users\Jaapp\Documents\GitHub\xbmc\project\VS2010Express\XBMC.vcxproj" (build target(s)) -- FAILED.
My build environment was fine. Did an upstream fetch and now it is no longer working. I deleted /xbmc/interfaces/python/generated, but that did not work. I deleted everything and made a new XBMC clone. That didn't work either! What is going on?
(2013-03-03, 21:06)WiSo Wrote: [ -> ]Do you have sp1 for vs2010 installed (comes with windows update)? If yes try to reinstall it.
Thanks, I've got .NET Framework 4.5 on the computer and that seems to cause some problems, will try some of the suggestions on the links.
I installed SP1 that I had missed for some reason and that solved my building problems, .NET Framework 4.5 is still installed.
Still curious about if the Wiki articles are up-to-date, and why Java is needed.
Depends on what you mean with "the Wiki articles". The compilation guide is pretty up to date. The rest not at all. As its a community driven project feel free to fix or add anything which is needed.
java is needed for groovy to generate our python bindings. See tools\codegenerator\GenerateSWIGBindings.bat.
I meant the articles in my first post, Java is only mention in one of them and SDL.dll wasn't in the dependecies directory.
I think the Wiki devolopment area is one I definitely should keep away from. Big Grin
Thanks for the help and the explanation about Java.
Sdl.dll isn't needed anymore.
