2013-03-03, 22:34
Hi!
I just started analysing the source of the pvr addon for DVBViewer Recording Service.
As I found out there are PVR API calls for XBMC to enable/disable the pause/seek buttons.
But these functions are never called by XBMC
PVRClient.cpp:
This function will be called on channel open/switch of XBMC.
As channel.StreamURL().IsEmpty is not empty (it's holding the url to the live stream) these functions are not called:
Should it not be this way:
Or I am missing somewhere else something?
PVRClient.cpp:
bool CPVRClient::OpenStream(const CPVRChannel &channel, bool bIsSwitchingChannel)
bool bReturn(false);
CloseStream();
if(!CanPlayChannel(channel))
CLog::Log(LOGDEBUG, "add-on '%s' can not play channel '%s'", GetFriendlyName().c_str(), channel.ChannelName().c_str());
else if (!channel.StreamURL().IsEmpty())
CLog::Log(LOGDEBUG, "opening live stream on url '%s'", channel.StreamURL().c_str());
bReturn = true;
// the Njoy N7 sometimes doesn't switch channels, but opens a stream to the previous channel
// when not waiting for a short period.
// added in 1.1.0
AddonVersion checkVersion("1.1.0");
if (m_apiVersion >= checkVersion)
unsigned int iWaitTimeMs = m_pStruct->GetChannelSwitchDelay();
if (iWaitTimeMs > 0)
XbmcThreads::ThreadSleep(iWaitTimeMs);
else
CLog::Log(LOGDEBUG, "opening live stream for channel '%s'", channel.ChannelName().c_str());
PVR_CHANNEL tag;
WriteClientChannelInfo(channel, tag);
try
bReturn = m_pStruct->OpenLiveStream(tag);
if (bReturn)
m_bCanPauseStream = m_pStruct->CanPauseStream();
m_bCanSeekStream = m_pStruct->CanSeekStream();
catch (exception &e) { LogException(e, __FUNCTION__); }
if (bReturn)
CPVRChannelPtr currentChannel = g_PVRChannelGroups->GetByUniqueID(channel.UniqueID(), channel.ClientID());
CSingleLock lock(m_critSection);
m_playingChannel = currentChannel;
m_bIsPlayingTV = true;
m_bIsPlayingRecording = false;
return bReturn;
CloseStream();
bReturn = true;
// added in 1.1.0
else
PVR_CHANNEL tag;
try
if (bReturn)
return bReturn;
