(2013-11-25, 13:58)MilhouseVH Wrote: [ -> ] (2013-11-25, 13:01)redglory Wrote: [ -> ]My stacked movie fanart are defined as: Movie.dvdrip.cd1.avi | Movie.dvdrip.cd2.avi is set as Movie.dvdrip-fanart.jpg (it removes part numbering)
OK there's a new version of mklocal.py up on github that should support this, it will strip out the cd/disc/part/whatever so in the above case it should find artwork named as "Movie.dvdrip-fanart.jpg" (fingers crossed).
I'll let you know as soon as I get home
Thanks mate!
Here it is my
log
And this is what I have on my textures13.db regarding Zombieland:
E:\Movies\Zombieland.(2009)/clearart.png
Don't have logo cached and as you've stated, slash and backslash are the cause of converting clearart
Looks great!
Cool, time to pull the trigger and update your media library with "texturecache.py set" !
Although I thought you said you had remote artwork, when much of your library artwork appears to be local (but mangled), in which case "texturecache.py fixurls | texturecache.py set" would work well for you.
(2013-11-26, 00:48)MilhouseVH Wrote: [ -> ]Cool, time to pull the trigger and update your media library with "texturecache.py set" !
It's being updated! All my artwork is local but not in XBMC library... That's why I want to re-cache everything!
This takes some time... now, updating Ocean's 13
(2013-11-26, 01:31)redglory Wrote: [ -> ]It's being updated! All my artwork is local but not in XBMC library... That's why I want to re-cache everything!
Ah right, OK.
(2013-11-26, 01:31)redglory Wrote: [ -> ]This takes some time... now, updating Ocean's 13
Yes, applying updates to the database with JSON can be slow, particularly if you have cast artwork - every row for the movie is deleted from the database even if you are updating only a single field, this can mean hundreds of rows being deleted then reinserted, just to change the value of one column on one row!
It's the kind of thing you might want to leave running overnight...
At least if you re-run this again it will only apply the changes that need to be changed, so once you've got the mass of updates out of the way, future runs should be relatively quick as you won't have so many changes.
All done for Movies (fanart poster clearlogo clearart)!
Tomorrow will look into tvshows
texturecache.py (Version 1.1.8):
- Add: rbphdmi option to manage Raspberry Pi HDMI power saving. Default delay is 900 seconds after screensaver has activated, specify alternative delay in seconds as second argument. View event activity with @debug=yes. Specify location of tvservice binary with @bin.tvservice property (default is /usr/bin/tvservice). Due to nature of operation, requires xbmc.host to be localhost.
To start automatically on OpenELEC, add to /storage/.config/autostart.sh as follows:
(sleep 20 && /storage/texturecache.py @logfile= @xbmc.host=localhost rbphdmi) &
Hey,
I'm trying to run:
python texturecache.py c movies
which is giving this error:
File "texturecache.py", line 5867, in <module>
main(sys.argv[1:])
File "texturecache.py", line 5745, in main
extraFields=_extraFields, query=_query)
File "texturecache.py", line 3132, in jsonQuery
cacheImages(mediatype, jcomms, database, data, title_name, id_name, force, n
odownload)
File "texturecache.py", line 3175, in cacheImages
parseURLData(jcomms, mediatype, mediaitems, imagecache, data, title_name, id
_name)
File "texturecache.py", line 3424, in parseURLData
for file in jcomms.getExtraArt(item):
File "texturecache.py", line 1763, in getExtraArt
for file in data["result"]["files"]:
TypeError: 'NoneType' object is not iterable
I've spotted the main(sys.argv[1:] and tried using command like
python texturecache.py c movies zombie
and everything runs as expected.
Anything I might be missing?!
redglory, can you run:
python texturecache.py c movies @logfile=c:\tc.log
and send me the file tc.log. I suspect I know what is going on, but will need some additional information to confirm, thanks.
Here you go:
log
It seems you always expect a folder with files inside.
2013-11-28 23:18:31.254000:MainThread: libDirectory.JSON SOCKET REQUEST: [{"jsonrpc": "2.0", "params": {"directory": "E:\\Movies\\42.(2013)\\extrathumbs\\"}, "method": "Files.GetDirectory", "id": "libDirectory"}]
2013-11-28 23:18:31.256000:MainThread: libDirectory.BUFFER RECEIVED (len 100)
2013-11-28 23:18:31.256000:MainThread: libDirectory.PARSING JSON DATA: {"id":"libDirectory","jsonrpc":"2.0","result":{"files":null,"limits":{"end":0,"start":0,"total":0}}}
2013-11-28 23:18:31.256000:MainThread: libDirectory.PARSING COMPLETE, elapsed time: 0.000000 seconds
2013-11-28 23:18:31.256000:MainThread: libDirectory.RECEIVED LIMITS: {u'start': 0, u'total': 0, u'end': 0}
2013-11-28 23:18:31.257000:MainThread: libDirectory.FINISHED, elapsed time: 0.003000 seconds
Forgot to mention that I have configured to cache both extrafanart and extrathumbs!
(2013-11-29, 01:48)redglory Wrote: [ -> ]Here you go: log
(2013-11-29, 01:48)redglory Wrote: [ -> ]It seems you always expect a folder with files inside.
Yes, and I've hit this problem before, so my mistake. It appears that some systems (maybe older XBMC versions) return "null" for "files" on empty directories, rather than no files property (or even just an empty list) whenever there are no files. I have a centralised GetDirectory method which I should have used on this occasion (when looking up the extra* art), but didn't.... now all Files.GetDirectory access goes through the centralised method which includes a work around for the data issue...
Thanks for reporting.
texturecache.py (Version 1.1.9)
- Chg: Tweak rbphdmi logic slightly: Check HDMI has actually turned on/off; don't turn off HDMI if the TV/monitor has been powered off (if supported by TV/monitor - if not, assume "always on" with @hdmi.force.hotplug=yes).
texturecache.py (Version 1.2.0)
- Fix: null being returned for files from Files.GetDirectory call on some systems - ensure centralised method used everywhere
Will try it while at home.
Now it's throwing this error:
Traceback (most recent call last):0, Multi thread 3951
File "texturecache.py", line 5872, in <module>
main(sys.argv[1:])
File "texturecache.py", line 5750, in main
File "texturecache.py", line 3137, in jsonQuery
odownload)
File "texturecache.py", line 3307, in cacheImages
if gLogger.VERBOSE and gLogger.LOGGING: gLogger.log("QUEUE ITEM: %s" % item)
File "texturecache.py", line 2704, in __str__
self.libraryid, self.missingOK)
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 17: ordinal
not in range(128)
Here is my
tc.log
f not MyUtility.isPython3:
try:
v = bytes(v.encode("iso-8859-1")).decode("utf-8")
except UnicodeDecodeError:
pass
return v
It seems problem is in this encode/decode line:
Can't decode
Character ISO-8859-1 Unicode UTF-8 Bytes Name
à 0xC3 0x00C3 0xC3, 0x83 Latin Capital Letter A With Tilde
It might be because you'll first need to encode 'ascii' to 'unicode' and then to 'utf-8'?
@redglory: Thanks for the report and the log.
The problem appears to be with Les Misérables, and the extrafanart/extrathumbs files (that have to be quoted) not being converted to unicode strings as part of the quoting process so they don't subsequently encode/decode correctly, and eventually blow up when logged/output. The encode/decode you highlighted fails because the input string is not unicode, when it should be.
Although I've not been able to reproduce your exact error on my system, I've uploaded v1.2.1 which hopefully fixes the issue. If you could test and let me know that would be great, thanks!
Just an update to say I've now reproduced the problem reported by redglory and the
fix in v1.2.1 does the trick!
