I installed XBMC 11 on a new build after testing it on my laptop and liking it. On the new PC I had extreme stability issues. XBMC would crash almost every time I changed a setting and watch a movie. I noticed there was a new version so I uninstalled 11 and installed 12 Frodo. It runs better but still crashes during every movie at least once. If its a Blu Ray ISO its crashes after a few minutes.
DVD ISO Crash:
http://pastebin.com/iVAhMJXh
Blu Ray ISO Crash:
http://pastebin.com/UMZe0dHW
I looked at earlier logs and from the beginning I tried changing things like running as administrator and disabling Areo. Nothing helped.
Any help would be greatly appreciated.
Forgive me if I sound impatient. Did I not post this issue correctly? Or is the support forum not very active? This is the only thing holding me up from using my new HTPC. I appreciate any help on this issue.
Look in you log folder if you find any .dmp files. Upload them somewhere and post link here. This could tell us more than the logfiles alone.
Thanks for the reply. I did not see a .dmp file when I originally posted this but when I looked this morning I saw two from the 5th just 10 seconds apart.
http://www.2shared.com/file/jO9shgwH/xbm...30127.html
http://www.2shared.com/file/T6g2B4Eg/xbm...30127.html
Update since my first post. I went to AMDs website and used their auto detect option to download drivers for the A10 5800k APU. Still crashes. I have come to the conclusion that its not an XBMC issue. I tested playing the actual Blu Ray disc in both XBMC and TMT5. So this tells me its a drive/hardware issue but I hope the XMBC logs will point me in the right direction.
Unistall and installed the most recent nightly date 03/09/13.
No dmp file present but the Log Report is below. It did behave differentlly this time. It played about 5 minutes then looped back to the beginning. After looping it crashed the computer around 5-10 seconds in.
http://pastebin.com/TyFkjfru
