Full Version: Hackintosh Windowed Mode Question
Hey there XBMC community! This is my first post. I hope you will welcome me.
I have built a touchscreen all in one Mac OS X machine as a type of budget iMac. I call it an EeeMac. Tongue
Everything works great, with the exception of one problem. Some applications, when full screen, cause the machine to kernel panic.
XBMC, by default, starts in full screen mode. Well, BANG! Kernel panic.
It does not stay open long enough to create a userdata folder. It does not stay open long enough to allow me to use the "\" hotkey to toggle windowed mode.
I would write my own guisettings.xml but I have never taken a look at one so I do not know the full syntax - though the wiki has a great list of arguments to use.
Does anyone know of a way to start XBMC in windowed mode? Or can you share your userdata folder or guisettings.xml so I can create it manually?
Thanks go out to all of the community and devs. Superb job on a superb piece of software.
i would instead try to fix the panic. In which kext does the panic appear and which osx version are you using?
No thanks. The panic is due to a removal of AppleIntelIntegratedFramebuffer.kext on 10.6.3 retail in order to get QE/CI working. I'd rather have this issue than no hardware acceleration. That's the same reason I'm not on 10.6.8.
Anyway, I just need someone's XBMC folder. Or guisettings.XML. My problem is not fixing the panic. I just need XBMC to open in windowed mode.
Okay, since nobody will share their folder, I copied mine over from my Windows install.
Now, how can I use guisettings.xml to set windowed mode to start automatically?
Smile
Well if nobody sends their advanced settings you could use yours from windows again.... AFTER you switched your win xbmc to window mode.
Just fyi - i'm running 10.6.8 with QC/CE on intel x3100 gfx (patched framebuffer). But yeah - what pecinko said.
