Full Version: epg timeline, single button to select
Hi, i hope this is the best place to post this..
is there some way within the timeline epg to select and tune to a channel without bringing up the sub menu and moving from the default ok option to the select option ?
hope that's a clear enough explanation
Will
I am also searching for this option.
Hello All,
This feature request has been looged here: http://forum.xbmc.org/showthread.php?tid=154675
Also within this thread is a workaround for instant tuning on pressing "OK" button via "advancedsettings.xml", however the workaround will disable the pop-up window you mention less you press the "i" button instead of "OK".
Many thanks,
Guy
