Full Version: Ability to filter shows/movies by online media or dvd/offline
Hi
I've added a bunch of stub files into my Movie and TV collectionsv. It shows everything I have and works great!!!
I think it would be cool to add a filte for ONLINE only. Sometime, I'd like to see what is available online without hunting up a DVD, Blueray, Tape, etc. I know the fact the media is a stub/offline is saved as it displays the dvd symbol on offline/dvd movies.
I know there is a filter function. Can this be incorporated into it?
phil
You already can, by using a Smart Playlist or Custom Video Node that filters on filename, "ends with .disc".
(2013-03-08, 03:08)sialivi Wrote: [ -> ]You already can, by using a Smart Playlist or Custom Video Node that filters on filename, "ends with .disc".
Will that work in library mode?
Yes, in fact, smart playlists only work with library content.
I installed AEON Flux (?) and love it
I've added a few menu items and added my online and offline features to the submenus and it works great! I set the directories up so that the 2 types are stored in different file locations, making te code easy to write.
