Quote:167238752750
That's a timestamp from ezechiel1917's log. It's also beyond the 26 hours mark.
FernetMenta: That was from DVB-C channel.
I'll try to post proper log when this happens again. Movie with that mono audio already ended.
I do not check this channel very often. The last occourences of this issue were Mar 23 0:42 - 1:45 and Mar 23 15:15 and today 20:15 - 21:00. At Mar 23, the time difference was too short for this 26hr wrap, but from Mar 23 15:15 to today 20:15 it could.
I don't think you have tuned to those channels for longer than 30 hours, right?
So there must be a problem in reading the timestamps. I will try to use the pcr stream for error correction.
(2013-03-25, 23:44)FernetMenta Wrote: [ -> ]I don't think you have tuned to those channels for longer than 30 hours, right? So there must be a problem in reading the timestamps. I will try to use the pcr stream for error correction.
Yes, you're right. I only switch to the channel, looking if it stutters or not and then stopping it
checked again, and it's not related to mono audio because that channel currently still stutters.
(2013-03-26, 00:37)ezechiel1917 Wrote: [ -> ]checked again, and it's not related to mono audio because that channel currently still stutters.
I think I localized the problem, at least I can construct a case where timestampa are set incorrectly. Will push a fix tomorrow.
I pushed a fix to vnsi4. The error I hopefully fixed would explain the occasional stuttering.
(2013-03-27, 11:21)FernetMenta Wrote: [ -> ]I pushed a fix to vnsi4. The error I hopefully fixed would explain the occasional stuttering.
Perfect
Thank you
Now, will wait for the issue an than testing your new vnsi plugin, which I have already build and pre-tested
unfortunately affected channel is still stuttering after recompile. Here's log of this channel -
http://pastebin.com/nUa06k8P . Let me know if you need any other information, I will gladly help.
Can you provide a 1-2 minutes recording of this channel when this issue occurs?
when updating the xbmc addon / vdr plugin, will i need to reset any stuff in xbmc?
