Full Version: Reverting to file name after erroneous match?
When XBMC loaded my library and automatically matched my videos, it got most of them, but not all. (For example, it identified the Babylon 5 episode "A Distant Star" as the movie "Wanda the Sadistic Hypnotist." Really.)
If all attempts to find the right thing fail, is there a way to get it to forget what it found and revert to the filename? I've checked the docs, Wiki, and FAQs but not spotted how to do this.
While selected, bring up the context menu (C on a keyboard) and select "remove from library".
(2013-03-09, 06:17)Ned Scott Wrote: [ -> ]While selected, bring up the context menu (C on a keyboard) and select "remove from library".
When I press "C", I get the following options:
Queue item
Play from here
Add to favourites
Movie information
Mark as watched
Update library
but not "Remove from library". Should I be looking elsewhere?
This is using Eden on Ubuntu Linux, on which Frodo apparently doesn't work.
Select it from the Movie view instead of the file view.
