Full Version: Adding media sources
Is there a way to add a media source without going through the file window of the respective category?
Right now I have a menu button that activates the DialogMediaSource.xml. Its list does not have any entries (not even the default <none>) though.
To solve this I set the window's default control to the browse button, which, on focus, sends a click event to the add button.
So now I have an empty list entry and can browse. The path updates just fine. However when I click ok, the new directory isn't actually added to my sources. And I'm not getting the "select content" screen either.
Does anybody of you guys know a solution?
Or an alternative way of adding sources from within the library windows?
Not possible I think.
Only making an addon to write directly to your sources.xml
Let me know when when you created it, i still have an unfinished "setup wizzard" laying around that also needs this.
Haha, nice try. Big Grin
I'm pretty busy with the skin and would have to read up on Python first, so this likely won't happen.
