Pages: 1 2 3 4 5 6 7 8 9 10 11
in boblight-constant and so on I can set a value by typing -o value=20, this value is the brightness of the leds.
maybe this is something for you:
http://jscolor.com/
Not a color wheel, but you can pick colors (which preview), too.
(2013-03-15, 19:02)YoBnEb Wrote: [ -> ]in boblight-constant and so on I can set a value by typing -o value=20, this value is the brightness of the leds.
maybe this is something for you: http://jscolor.com/
I have to look at that, the problem is, there is no API, so I have to look at the boblightcode to see what I can do.
Oh, thats what you meant...
A color picker wheel.
I thought you meant a color wheel for LEDs like a "spinning" animation or something.
Should be no problem when I find some time.
Heh, nice app
Too bad I don't have a smartphone.
Very nice app.
But as soon as it connects to boblight, the app is crashing on the phone.
I can see the incoming connection on the system where boblight is running and then booooom force close.
Any ideas?
Device is a HTC Desire with Android 4.1.
Is there a log file in your Sd card root? I have no problems on 4.2 so it's probably a compatibility issue with 4.1.
Fixed, I checked for Android version but forgot that JellyBean is 4.1 and 4.2.
Should work on everything now.
Still the same link.
Great to hear.
Will check it as soon as possible.
The app is working great!
It's working now for me.
Except that the LEDs are stuck from time to time, but I blame the raspberry here.
Sometimes the leds are stuck when the connection "breaks" but boblight somehow still thinks the client is connected.
If something is stuck just lower the Priority in settings and it should work again until you disconnect then you are back at the stuck color.
If you set the priority higher than XBMC which is 128 I think you can set a color and when you start a movie the XBMC addon works like normal.
Any ideas/requests/suggestions?
I need something to do
OK here you go then
Lights ON/OFF is a bit confusing imo as for me it switches between the configured backlight in addon setting to the Bobdroid control.
A bigger control circle would be nice as it seems a bit tiny at least on my Nexus7
Switching between Mood light and constant turn the switch off. Personally i would expect it to stay on.
An exit button perhaps? I found out that if you switch light off and unfocus the app it exits bit it's not that clear.
Any way of controlling the boblight settings during playback? This saves some time going back and forth to the addon settings to tweak the settings to get them right.
Other than that nice app
