aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC892 Analog [ALC892 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC892 Digital [ALC892 Digital]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
sysdefault:CARD=PCH
HDA Intel PCH, ALC892 Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=PCH,DEV=0
HDA Intel PCH, ALC892 Digital
IEC958 (S/PDIF) Digital Audio Output
hdmi:CARD=PCH,DEV=0
HDA Intel PCH, HDMI 0
HDMI Audio Output
XBMC debug log output:
22:01:26 T:140463227119360 INFO: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=PCH,DEV=0"
22:01:26 T:140463227119360 INFO: CAESinkALSA::Initialize - Opened device "hdmi:CARD=PCH,DEV=0,AES0=0x06,AES1=0x82,AES2=0x00,AES3=0x02"
22:01:26 T:140463227119360 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 512, periods 16, bufferSize 8192
22:01:26 T:140463227119360 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 512, periods 16, bufferSize 8192
22:01:26 T:140463227119360 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 171 ms
22:01:26 T:140463227119360 DEBUG: CSoftAE::InternalOpenSink - ALSA Initialized:
22:01:26 T:140463227119360 DEBUG: Output Device : HDA Intel PCH
22:01:26 T:140463227119360 DEBUG: Sample Rate : 48000
22:01:26 T:140463227119360 DEBUG: Sample Format : AE_FMT_S16NE
22:01:26 T:140463227119360 DEBUG: Channel Count : 2
22:01:26 T:140463227119360 DEBUG: Channel Layout: FL,FR
22:01:26 T:140463227119360 DEBUG: Frames : 512
22:01:26 T:140463227119360 DEBUG: Frame Samples : 1024
22:01:26 T:140463227119360 DEBUG: Frame Size : 4
22:01:26 T:140463227119360 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 2048
22:01:26 T:140461662529280 DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
22:01:26 T:140462534944512 DEBUG: CDVDPlayer::HandleMessages - player started 2
22:01:26 T:140462534944512 DEBUG: CDVDPlayer::HandleMessages - player started 1
22:01:26 T:140462534944512 DEBUG: CDVDPlayer::SetCaching - caching state 0
22:01:26 T:140463227119360 DEBUG: CSoftAE::Run - Sink restart flagged
22:01:26 T:140463227119360 INFO: CSoftAE::InternalOpenSink - RAW passthrough enabled
22:01:26 T:140463227119360 INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_AC3, FL,FR, 48000hz
22:01:26 T:140461662529280 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(32000.000000, 1)
22:01:26 T:140461662529280 DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:-180464.036667, should be:-180462.626667, error:1.410000
22:01:26 T:140463545837504 DEBUG: CLinuxRendererGL::UploadVAAPITexture - creating vaapi surface for texture 0
22:01:26 T:140463545837504 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
22:01:30 T:140461670921984 DEBUG: CPullupCorrection: detected pattern of length 1: 33366.67, frameduration: 33366.666667
Evereything works perfectly over HDMI between this system and my TV, it just hates my receiver, and it seems to be something within my Arch install that hates it. Ubuntu and windows work perfectly fine with the receiver out of the box, i'm just not willing to switch to either of them.
