I got it. Here's the XML if anyone wants it.
<item>
<title>NHK WORLD</title>
<link>rtmp://ny-1.srv.fivecool.net/nhkw/gwm swfUrl=http://www3.nhk.or.jp/nhkworld/r/movie/streamhub_player20130222.swf pageUrl=http://www3.nhk.or.jp/nhkworld/w/movie/</link>
<thumbnail>http://cdn.realscreen.com/wp/wp-content/uploads/2012/02/nhk.jpg</thumbnail>
</item>>
Thanks for this info! I've been looking for a way to view this stream using IPTVSimple. I got it working perfect and even have created a simple DOS program to get the EPG from the NHK World site and add it to my XMLTV file from mc2xml.
If anyone is interested here is the code I created. I'm including the code in case the url/structure changes in the future.
I used mc2xml from
http://mc2xml.hosterbox.net and wget from
http://users.ugent.be/~bpuype/wget/. Both files were put into a resources folder too keep things nice and organized.
IPTVSimple
#EXTINF:-1 tvg-id="NHKWorld" tvg-name="NHKWorld" tvg-logo="" tvg-shift="-13" group-title="Cable",1 NHK World
C++ Code to convert NHK World RSS feed to XMLTV format.
#include <fstream>
#include <iostream>
#include <cstdlib>
#include <cstring>
using namespace std;
int main(int argc, char** argv)
int start = 1;
ofstream xmlfile;
xmlfile.open("nhk.xml");
system(".\\resources\\wget.exe -O nhk.rss http://www3.nhk.or.jp/nhkworld/english/epg/nhkworld_program.xml");
/* Start XMLTV File Structure
xmlfile << "<?xml version=\"1.0\" encoding=\"ISO-8859-1\"?>\n";
xmlfile << "<!DOCTYPE tv SYSTEM \"xmltv.dtd\">\n\n";
xmlfile << "<tv source-info-name=\"Zap2it\" generator-info-name=\"mcxml\" generator-info-url=\"mailto:[email protected]\">\n";
xmlfile << " <channel id=\"NHKWorld\">\n";
xmlfile << " <display-name>NHK World</display-name>\n";
xmlfile << " </channel>\n";
ifstream file;
/* Read RSS data into Structure
file.open("nhk.rss");
int i = 0;
while(!file.eof())
char buffer[1024];
char starttime[21];
char time[3][21];
char title[3][1024];
char description[3][1024];
file.getline(buffer,1024);
string temp = (char*)buffer;
// Check Start Time
if(strncmp(buffer,"<pubDate>",9) == 0)
time[i][0] = buffer[21];
time[i][1] = buffer[22];
time[i][2] = buffer[23];
time[i][3] = buffer[24];
time[i][4] = 'X';
time[i][5] = 'X';
time[i][6] = buffer[14];
time[i][7] = buffer[15];
time[i][8] = buffer[26];
time[i][9] = buffer[27];
time[i][10] = buffer[29];
time[i][11] = buffer[30];
time[i][12] = buffer[32];
time[i][13] = buffer[33];
time[i][14] = ' ';
time[i][15] = buffer[35];
time[i][16] = buffer[36];
time[i][17] = buffer[37];
time[i][18] = buffer[38];
time[i][19] = buffer[39];
time[i][20] = '\0';
if ((buffer[17] == 'J') && (buffer[18] == 'a') && (buffer[19] == 'n')) { time[i][4] = '0'; time[i][5] = '1'; }
else if((buffer[17] == 'F') && (buffer[18] == 'e') && (buffer[19] == 'b')) { time[i][4] = '0'; time[i][5] = '2'; }
else if((buffer[17] == 'M') && (buffer[18] == 'a') && (buffer[19] == 'r')) { time[i][4] = '0'; time[i][5] = '3'; }
else if((buffer[17] == 'A') && (buffer[18] == 'p') && (buffer[19] == 'r')) { time[i][4] = '0'; time[i][5] = '4'; }
else if((buffer[17] == 'M') && (buffer[18] == 'a') && (buffer[19] == 'y')) { time[i][4] = '0'; time[i][5] = '5'; }
else if((buffer[17] == 'J') && (buffer[18] == 'u') && (buffer[19] == 'n')) { time[i][4] = '0'; time[i][5] = '6'; }
else if((buffer[17] == 'J') && (buffer[18] == 'u') && (buffer[19] == 'l')) { time[i][4] = '0'; time[i][5] = '7'; }
else if((buffer[17] == 'A') && (buffer[18] == 'u') && (buffer[19] == 'g')) { time[i][4] = '0'; time[i][5] = '8'; }
else if((buffer[17] == 'S') && (buffer[18] == 'e') && (buffer[19] == 'p')) { time[i][4] = '0'; time[i][5] = '9'; }
else if((buffer[17] == 'O') && (buffer[18] == 'c') && (buffer[19] == 't')) { time[i][4] = '1'; time[i][5] = '0'; }
else if((buffer[17] == 'N') && (buffer[18] == 'o') && (buffer[19] == 'v')) { time[i][4] = '1'; time[i][5] = '1'; }
else if((buffer[17] == 'D') && (buffer[18] == 'e') && (buffer[19] == 'c')) { time[i][4] = '1'; time[i][5] = '2'; }
else { time[i][4] = 'X'; time[i][5] = 'X'; }
if(start == 1)
if(i == 1) { strcpy(starttime,time[0]); }
// Check Title
if(strncmp(buffer,"<title>",7) == 0)
temp.erase(0,7);
temp.erase(strlen(temp.c_str()) - 8,8);
strcpy(title[i],temp.c_str());
// Check Description
if(strncmp(buffer,"<description>",13) == 0)
temp.erase(0,13);
temp.erase(strlen(temp.c_str()) - 14,14);
strcpy(description[i],temp.c_str());
// Check Program Setup
if((strncmp(buffer,"<item>",6) == 0) || (strncmp(buffer,"</channel>",10) == 0))
if(start == 1)
if(i == 1) start = 0;
i++;
else
switch(i)
case 0:
xmlfile << " <programme start=\"" << time[2] << "\" stop=\"" << time[0] << "\" channel=\"NHKWorld\">\n";
xmlfile << " <title lang=\"en\">" << title[2] << "</title>\n";
xmlfile << " <desc lang=\"en\">" << description[2] << "</desc>\n";
xmlfile << " </programme>\n";
i = 1;
break;
case 1:
xmlfile << " <programme start=\"" << time[0] << "\" stop=\"" << time[1] << "\" channel=\"NHKWorld\">\n";
xmlfile << " <title lang=\"en\">" << title[0] << "</title>\n";
xmlfile << " <desc lang=\"en\">" << description[0] << "</desc>\n";
i = 2;
break;
default:
xmlfile << " <programme start=\"" << time[1] << "\" stop=\"" << time[2] << "\" channel=\"NHKWorld\">\n";
xmlfile << " <title lang=\"en\">" << title[1] << "</title>\n";
xmlfile << " <desc lang=\"en\">" << description[1] << "</desc>\n";
i = 0;
break;
file.close();
xmlfile << "</tv>\n";
xmlfile.close();
system(".\\resources\\mc2xml.exe -I nhk.xml -D .\\resources\\mx2xml.dat -o XMLTV.xml");
system("erase nhk.rss");
system("erase nhk.xml");
return 0;
