2013-03-10, 20:07
Good morning,
I am using XBMC on appletv based on Crystalbuntu, I am having trouble with few avi files only video play no audio, these are xvid files i tried tinkering around with codecs but no help
The same file play on appletv 1 without Crystalbuntu
Appreciate any help from the forum
General
Complete name :
Format : AVI
Format/Info : Audio Video Interleave
File size : 9.23 MiB
Duration : 1mn 2s
Overall bit rate : 1 247 Kbps
Writing library : Boilsoft AVI tool build 30012/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1mn 2s
Bit rate : 1 140 Kbps
Width : 640 pixels
Height : 272 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.273
Stream size : 8.44 MiB (91%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1mn 2s
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Sampling rate : 32.0 KHz
Delay relative to video : 34ms
Stream size : 728 KiB (8%)
Alignment : Split accross interleaves
Interleave, duration : 42 ms (1.01 video frame)
Interleave, preload duration : 500 ms
General
Complete name :
Format : AVI
Duration : 1mn 2s
Video
Codec ID : XVID
Duration : 1mn 2s
Width : 640 pixels
Height : 272 pixels
Color space : YUV
Bit depth : 8 bits
Audio
Format : MPEG Audio
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1mn 2s
