Full Version: [Linux] Frodo problems playing 25fps content
I'm having a problem playing 25fps content from the UK, it is playing at a 60hertz refresh rate in frodo. When i was using eden my modelines in my xorg.conf would force XBMC and my tv to switch to the proper 50hertz refresh rate but its seems my xorg.conf no-longer works in frodo. In XBMC I have these setting enabled
"Vertical blank sync" ALWAYS ENABLED
"Allow hardware acceleration" ON
"Adjust display refresh rate" ON
"Sync playback to display" ON
"A/V sync method" VIDEO CLOCK (RESAMPLE AUDIO)
Any help would be appreciated.
Section "Device"
    Identifier     "nvidia"
    Driver         "nvidia"
    Option         "DynamicTwinView" "False"
    Option         "NoFlip" "false"
    Option         "NoLogo" "true"
    Option         "ConnectToAcpid" "0"
    Option         "FlatPanelProperties" "Scaling = Native"
    Option         "ModeValidation" "NoVesaModes, NoXServerModes"
    Option         "HWCursor" "false"
    # To put Xorg in debug mode change "false" to "true" in the line below:
#    Option         "ModeDebug" "false"
    # To use a local edid.bin file uncomment the 4 lines below (change DFP-0 to match your card)
#    Option         "ConnectedMonitor" "DFP-0"
#    Option         "CustomEDID" "DFP-0:/storage/.config/edid.bin"
#    Option         "IgnoreEDID" "false"
     Option         "UseEDID" "true"
EndSection
Section "Monitor"
    Identifier     "Monitor"
    VendorName     "Unknown"
    ModelName      "Unknown"
#    HorizSync       28.0 - 33.0
#    VertRefresh     43.0 - 72.0
    Option "ExactModeTimingsDVI" "TRUE"
    HorizSync 31 - 82
    VertRefresh 57 - 63
    ModeLine "[email protected]" 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
    ModeLine "[email protected]" 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
    ModeLine "[email protected]" 74.16 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync
    Modeline "[email protected]" 74.23 1920 2560 2604 2752 1080 1084 1089 1125 +hsync +vsync
    ModeLine "[email protected]" 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
    ModeLine "[email protected]" 89.01 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync
EndSection
Section "Screen"
    Identifier     "screen"
    Device         "nvidia"
    Monitor        "Monitor"
    DefaultDepth    24
#    Option         "ColorRange" "Full"
     Option         "ColorRange" "Limited"
#    Option         "ColorSpace" "RGB"
#     Option         "ColorSpace" "YCbCr444"
    SubSection     "Display"
        Depth       24
        Modes "[email protected]" "[email protected]" "[email protected]" "[email protected]" "[email protected]" "[email protected]"
    EndSubSection
EndSection
Section "Extensions"
    Option         "Composite" "false"
EndSection
Has anyone been able to get a custom xorg.conf to work in frodo? I'm not sure what I'm doing wrong.
Try have a look at the last link on my signature for guidance.
uNi
Xbmc has nothing to do with Xorg and its config.
