2013-03-11, 17:35
I'm sorry, I really wish I could've nailed this down a little more specifically before I posted, but I could not (that fact also made it difficult to google it). Here goes:
I finally updated to Frodo on saturday. I run a MySQL database on a Synology and XBMC on Mac OSX, PC, Android and, lastly but most importantly, Win7 on my HTPC. My HTPC is where I'm experiencing most of my issues, but its also the one I've used the most/done the most testing on, so it may not be as specific to the Win7 installation as I'm currently experiencing. I'm experiencing very random hangs/freezes. For instance if I fire up XMBC and go to a random show it seems ok, but if I go to an episode of Twin Peaks it will AT BEST start playing the sound but the video will never show up on the screen. Opening up XBMC and going straight to Twin Peaks did this about 5 times in row. One time I opened an episode of Louie first, and it played, I then navigated to Twin Peaks and clicked on the show and this time it didn't even open the Twin Peaks "folder". The "waiting dialog" with the spinning circle was on the screen and I could hear navigation sounds if I press up and down til eventually everything freezes. Funny thing is, I navigated to Twin Peaks on my ATV2 client and it played!
Also I was watching an episode at a time of Friday Night Lights and every time I'd finish, XBMC would bring me back to the episode list, with the episode I just watched marked as unread and would be frozen. When I close down xbmc, relaunch it and navigate back to Friday Night Lights, the episode I just watched would be marked watched and I can watch another episode but the same thing would happen when the episode was over. Maybe an issue when its being marked as watched?
I thought maybe it was an issue with Trakt utilities so I disabled it but that didn't seem to do anything.
I don't see a crashreport but here's my log: pastbin.com/Q1FVhCSk
As some additional color: because one of my installations is a ATV2, I kept my Thumbnails folder in the same Videos folder than contains my Movies and TV shows and use Path Substitution still in my Advanced Settings. Also, I still have <name>xbmc_video</name> in the <videodatabase> section of Advanced Settings even though that is supposedly unnecessary now. When I took it out, my Movies and TV's didn't load and I saw the endless "Unable to Open Database Errors" that I became ALL TOO familiar with during my update to Eden (which ended in me just blowing out my database and starting over). here's one of those logs: pastebin.com/j2DU82zh
Any help/ideas would be GREATLY appreciated. Should I forcibly uninstall all my plugins? specifically those that are "broken in the depository"? Should I save myself the headache and just start over? once again? I suspect its related to NFS permissions again, but nothing has changed from my Eden installation and I didn't experience anywhere near this amount of issues.
Edit: This seems to be my exact problem: http://forum.xbmc.org/showthread.php?tid=119855&page=13
Edit2: Here's after I removed all the Frodo created db's and the <name> tag from my Advanced Settings...http://pastebin.com/EGbjqjAL
Edit3: From some messages in the post I decided to see if the video would come back if I left it to "play" just the audio for an extended period of time. and it did! I tested 2 different files and in each case, just the audio played over an appearingly frozen menu for roughly 2 minutes at which point the file played normally. Does anybody have any ideas at all?
