Full Version: Cutomize Menu & audio clip
Hi all,
I am new to transparency, and i want to use the customize menu option :
But i don't understand how it's work
I would like to have a direct link to my anime source for exemple ( wich point on my anime folder)
My another problem : why i can see only one audio clip ?
Someone can help ?
Thanks !
1) add the anime source to favourites first, then map that favourite to a custom enu button.
note: if you're using windows + xbmc eden, it might not work correctly.
2) most likely because there are no good musicvideo scrapers.
thanks for 1), it work
and ok for 2)
