Hi.
I have got a problem lately. XBMC fails to eject my dvd discs. Everything else works (ie the disk is automatically mounted upon insertion and all movies works), but when I push eject nothing happens. Tried to find any error message in the logs but I find nothing at all. Running "eject" from terminal (logged in as the same user that XBMC runs as) works fine. How does XBMC try to eject the disc?
This is a Ubuntu 12.04.2 LTS box running XBMC 12.0 installed from ppa.
I have a slot-in player without any physical eject button, so now I have to ssh into the htpc everytime I want to remove a disc. Kinda irritating
/Daniel
Add the following to
/etc/sysctl.conf
(2013-03-12, 13:59)teeedubb Wrote: [ -> ]Add the following to /etc/sysctl.conf
Strange... I know I did that once, but now it was gone. Must've been many upgrades ago :-)
Anyway, it didn't work. Added the line and restarted, but still nothing happens when xbmc tries to eject the disc
/Daniel
Here
cd /lib/udev/rules.d/
nano 60-cdrom_id.rules
Change this:
IMPORT{program}="cdrom_id --lock-media $tempnode"
to this:
IMPORT{program}="cdrom_id $tempnode"
Done!
uNi
(2013-03-12, 18:07)uNiversal Wrote: [ -> ]Here
Change this:
to this:
Done!
That made the trick. Thanks a lot!
/Daniel
Uni,
just out of curiosity, how did you get to that solution? I mean, does a simple "apropos dvd", "apropos eject" or whatever do the trick, or do I have to read through tons of documentation? If so, which tons?
Ciao
Tom
I first came across it, researching the "problem" which I experienced myself in archwiki and most of it is ubuntu compatible, but when googled it turns up a few places. apropos leads no where of consequence anyway.
uNi
You should copy the modified rule fromĀ /lib/udev/rules.d/ to /etc/udev/rules.d/ as any rules in the lib folder can be overwritten during a update.
solution worked for me too, thanks very much. I am almost 100% completely satisfied with XBMC, just need to get my wii working as a remote and i am completely done! It would also be awesome for hbogo to work from the ipad but that is a horse of another color. XBMC is fantastic. I am running it via ubuntu and have a 2 TB drive with all my media on it and it has YET to fail to play ANYTHING. Superb work and such a wonderful wonderful tool!
Patrick Pagano
Digital Worlds Institute
University of FLorida
Thanks for the solid information!!!
Change this:
to this:
Done!
uNi
