2013-03-13, 00:34
Hi there,
I've been using XBMC for quite some time now, but just recently got interested into customizing it more.
So, I have a PlayStation 2 controller connected to my PC via an USB converter and wanted to map the keys so that I could use the controller for XBMC. Under Control Panel > Gamecontroller > Twin USB Vibration Gamepad > Properties it shows twelve buttons and four axes (X, Y, Rz, and Z). In the code below, I labeled the "image" with id numbers of the keys and axes from the Windows properties.
Everything seems to work fine except the right analog stick, which has the Rz and Z axes. I want to assign the volume control to the right analog stick: Left for VolumeDown and Right for VolumeUp. But with id="3" it's up and down for the volume (even though in Windows "3" is for Rz axis). So then I tried it with id="4" but nothing at all happened.
Does anyone have an idea what the problem is? Thanks for any help!
<!-- PS2-Controller -->
<!-- (Twin USB Vibration Gamepad) -->
<!-- Buttons: -->
<!-- / _5__ \ / __6_ \ -->
<!-- | 7 |_________| 8 | -->
<!-- // | 9 10 / 1 \\ -->
<!-- || -=X=- ___ ___ 4 2 || -->
<!-- \\ | / _ \ / _ \ 3 // -->
<!-- \ ||_|| ||_|| / -->
<!-- | \___/ \___/ | -->
<!-- | | 11 12 | | -->
<!-- \____/ \_____/ -->
<!-- Axes: -->
<!-- Left Analog Stick -->
<!-- X-Axis (1): -L +R -->
<!-- Y-Axis (2): -U +D -->
<!-- Right Analog Stick -->
<!-- Rz-Axis(3): -L +R -->
<!-- Z-Axis (4): -U +D -->
<keymap>
<global>
<joystick name="Twin USB Vibration Gamepad">
<hat id="1" position="up">Up</hat>
<hat id="1" position="down">Down</hat>
<hat id="1" position="left">Left</hat>
<hat id="1" position="right">Right</hat>
<button id="2">Back</button>
<button id="3">Select</button>
<button id="6">FULLSCREEN</button>
<button id="4">ContextMenu</button>
<axis id="2" limit="-1">ScrollUp</axis>
<axis id="2" limit="+1">ScrollDown</axis>
<axis id="3" limit="-1">VolumeUp</axis>
<axis id="3" limit="+1">VolumeDown</axis>
<button id="12">Mute</button>
</joystick>
</global>
<FullscreenVideo>
<hat id="1" position="up">BigStepForward</hat>
<hat id="1" position="down">BigStepBack</hat>
<hat id="1" position="left">StepBack</hat>
<hat id="1" position="right">StepForward</hat>
<axis id="1" limit="-1">AnalogSeekBack</axis>
<axis id="1" limit="+1">AnalogSeekForward</axis>
<button id="3">OSD</button>
<button id="7">Rewind</button>
<button id="8">FastForward</button>
</joystick>
</FullscreenVideo>
</keymap>
