Full Version: User Data
Hi All, i have XBMC installed on an android HDMI smart TV dongle, its running android 4.2.1. im trying to locate the user data directory, but looking at the explorer i cant find any files beyond--
/sdcard/Android/data/org.xbmc/files
there is nothing within the files directory, yet xbmc runs fine. and i have many plugins/skins installed. so where can it be?!
any help appreciated
O
You need to access the explorer settings and set it to allow you to see hidden files or some setting that says something like that.
(2013-03-14, 01:38)lartomar2002 Wrote: [ -> ]You need to access the explorer settings and set it to allow you to see hidden files or some setting that says something like that.
Thanks.. But.. On android?
Got it! Thanks!
