2013-03-14, 21:39
[I know that this is a common query but I did search on this topic before posting this thread ]
Like many others, I am plagued by missing media in my library. The problem is that I have many movies (as do we all) and I know that around 200-300 aren't showing up in XBMC. This is far too many to manually sift through and rename so I was wondering whether others had found an optimal solution to this task?
It looks like one has two ways to deal with missing movies:
1) Use the 'Missing Movie Search" plugin to identify which files haven't been added to your library. Link: http://code.google.com/p/xbmc-missing-movie-search/
2) Use a media manager to correctly rename files. List of options: http://wiki.xbmc.org/index.php?title=Cat...y_managers
As I mentioned above, if I use the missing movie plugin, it identifies 200-300 missing movies in a simple list output. That's useful but not THAT useful as I now have to manually go through my folders and match specific movies to my list so that I can rename them appropriately.
Alternatively, armed with my list of missing movies, I could use a media manager and manually go through and rename in this way.
I was wondering if there was a way for me to quickly separate out and rename ONLY the files identified as missing with the plugin in Step 1?
Any ideas? I've tried renamers (FileBot, TV Renamer, etc.) and media managers (Ember, etc.) but they all make the task unnecessarily difficult. I'm currently installing Media Center Master which looks like it has a slightly more intelligent interface so I hope that this does the trick.
