2013-03-20, 16:51
2013-03-23, 20:14
I notice this earlier, but forgot to say.
When you delete a movie. The popup message says : "movie added"
This can cause confusion. Because you didn't add the movie, but deleted it.
2013-03-23, 20:18
Thanks for the report, fixed.
Sadly this came about 5 minutes too late - I requested the addition to the official repository 5 minutes ago
2013-03-24, 01:22
This add-on is now in the official xbmc.org add-on repository (including the last minute string fixes). It should be available shortly via the add-on manager.
regards,
sphere
regards,
sphere
2013-03-24, 19:53
(2013-03-20, 16:51)sphere Wrote: [ -> ]Has anyone still problems/script-errors with this add-on?
I have a webroot set on my CP and I need to specify it in the port section but it won't allow anything but numbers. I need it to set the url as ip:port/webroot
If you have a look at the SickBeard Manager add-on, it allows it in that one. Thanks!
2013-03-24, 19:56
Yes, I am already working on adding the custom url part (already requested here). Just give me a few days and you will find a .zip with the new Version in this Thread ;-)
2013-03-24, 19:57
Missed that post....thanks a lot!
2013-03-24, 20:59
Ok, was easier than I thought, here is Version 0.0.4 with "Base Url" setting:
Download Version 0.0.4
@Aenima99x, @scooper86: Please tell me if this works for you.
regards,
sphere
regards,
sphere
2013-03-25, 11:43
base url is working fine
2013-03-25, 15:11
(2013-03-24, 20:59)sphere Wrote: [ -> ]Ok, was easier than I thought, here is Version 0.0.4 with "Base Url" setting:
regards,
sphere
Works perfect, Thanks!
2013-03-28, 01:12
Thanks for your feedback!
Just tell me if you have any other wishes
2013-03-29, 23:18
I added a new section to the initial post "Add-ons with integration", atm only "HD-Trailers.net" and "Apple iTunes Trailers". If you have added integration into your add-on and want in the list, just PM me.
2013-03-31, 07:13
regards,
sphere
Thanks for adding this, working fine!
2013-04-05, 01:04
does this only work with version 2 of CP? For some reason it doesn't detect my CP host (putting in the local IP). Unfortunately i'm on a ReadyNAS and version 2 isn't available for it.
2013-04-05, 09:08
Yes, this add-on only works with Version 2 (aka Couchpotato Server). Sorry.
