Indeed, thanks! I've pushed to fixes to github.com/fetzerch/xbmc-pvr-addons/ branch master (for xbmc pre-gotham) and branch frodo for frodo.
I'm running one Gotham box and one Frodo box, each running a version of the add-on reporting itself as 1.6.10. They both have the issue that the recording list does not update without a reboot. Do I need a newer version to get the fix?
I think you need to use either janbar or fetzerch's branch and build it yourself. As far as I know, it still hasn't made it into wider circulation.
i am running crystalbuntu 2.0 which is XBMC Frodo 12.1 on top of Ubuntu 12.04 and my current recordings don't show up either unless I reboot crystalbuntu 2.0 (original apple tv)
not sure what logs to provide as my xbmc.log file is huge!
(2013-04-22, 03:57)ubuntuaddicted Wrote: [ -> ]i am running crystalbuntu 2.0 which is XBMC Frodo 12.1 on top of Ubuntu 12.04 and my current recordings don't show up either unless I reboot crystalbuntu 2.0 (original apple tv)
Ahm ... did you read this thread and especially the last posts?
I submitted the patch to the xbmc addon repository. Its now up to the team to accept and release it.
where can i find out if the patch it being considered? just very annoying that I have to reboot my apple tv just to get the most recent recordings to show up. is there anyway i can patch my current addon install?
(2013-03-23, 02:15)janbar Wrote: [ -> ]Hi,
You can get the final patch like that: (for frodo or 13Alpha)
cd xbmc-pvr-addons
curl https://github.com/fetzerch/xbmc-pvr-add.../108.patch | git am
then make clean and compile addon.
To revert the patch:
git reset --hard HEAD~3
Or waiting cfetzer merge it. Br
how would I accomplish on an original apple tv? I can't seem to find the xbmc-pvr-addons directory.
Working well for me, all new recordings show up in xbmc. Thanks!
Does anyone know if this was put into 12.2?
(2013-05-03, 20:11)romanodog Wrote: [ -> ]Does anyone know if this was put into 12.2?
I just tried it this evening and it doesn't appear that the patch is part of the 12.2 release.
(2013-05-05, 07:15)jpavlocak Wrote: [ -> ] (2013-05-03, 20:11)romanodog Wrote: [ -> ]Does anyone know if this was put into 12.2?
correct, i just checked and it's not in Frodo 12.2 for me either.
Who knows...
Anyway, its trivial to compile yourself.
