Is their any way to add next aired info, previous episode and status of show to the tv shows multiplex view?
Just wanted to comment on how amazing this skin looks on a smaller screen. Using it on my 70 inch it looks good, but when you have the increased PPI of a smart phone it looks amazing.
I currently have this skin on my Android phone and I am loving it!
It works great with the touch implentation I'm VERY surprised. Great work on this skin, if you have a tablet, i strongly suggest you use Ace.
I am curious though, how do I change views on touch screens. Normally I hit left or up to bring up that menu, not sure how to do it on a touch screen.
tential, you need active option in settings skin, item general settings, and set ON for
Optimize skin for touch screen, this will solve access top menu, where change views.
Look images for visual reference:
and a help tab will appears in collection:
Thanks, also do you have any idea why I can only have 50 TVShows active in my library? I can't scrape anymore on Android for some reason. Works on my HTPC though.
Funny how easy the skin was to use though without that feature enabled lol.
Edit: This is just too sexy looking omg...
I can't wait til 4K screens/TVs are out to see this skin in UHD. The higher PPI really is just beautiful.
Edit2: Damn, you are just amazing haha. I figured it out easily from the text, but the images too. The help on this forum just makes using the skin that much better! I can't wait for my new Android tablet now.
tential, sorry, but I donĀ“t have idea about your troubles in tv shows.
Ha no problem I'll figure it out! I'm so excited playing with the skin now customizing all my windows now that I have the touch thing enabled lol.
Edit: going to the File location, hitting the menu button, and hitting scan for new content seems to have started up the scan again. Yay!
Quick question I always noticed this with ace, but not sure if its on my end, when using RCB all i seem to get when i scroll over to games is the most played widget, there is no in progress widget like there is with music movies or tv shows unless i scroll over the individual game itself then I get the now playing widget or whatever it is. So this is what it looks like when i scroll over games.
I have to physically scroll over onto a game before I get the other widget....this is not the case for movies, music or tv shows.
I am having trouble downloading the extrapack.
Every time I try it starts but after a while I get an "update failed" message. I tried deleting the skin database (from the skins settings menu) and start the download again.
First I get an "update not required" message and then after a while the download starts, but fails again with the above message.
Any ideas ?
Was just wondering, how well does this skin run with a rasp pi?
Has anyone else noticed that Watched status is no longer available after the update? Or is it just my setup?
Just enable it. In that collection when you're there, just toggle the thing that says "watched status" or whatever. It's on the right of viewtypes, I don't know what to call the window.
Thanks all. Found the FAQ and the other posts in the meantime that detail how to download it.
For reference, for linux the location is:
/home/username/.xbmc/userdata/addon_data/
(2013-07-09, 15:02)bry- Wrote: [ -> ] (2013-07-09, 09:26)seb0p Wrote: [ -> ]Hi,
can anyone say something about the Home Cinema Script?
What are you looking to read about the home cinema script?
Does it work in ace?
The supported skin list does not mention this awesomeskin
