Full Version: Remove big progress bar during pause.
Hi.
I was wondering if there is a way to remove/make the progressbar invisable when paused.
It takes up almost 1/3 of the screen. Only showing the word 'pause' at the top of the sceen would be sufficient i think.
2nd. I noticed that the info about the audiostream only tells the amount of chanels but not if it's Dolby or DTS.
It's not a big issue, but it would be nice.
thanks.
(2013-03-17, 10:08)Marco275 Wrote: [ -> ]I was wondering if there is a way to remove/make the progressbar invisable when paused.
For reFocus BIG:
I don't have access to my XBMC setup now, so I can't name the exact option.
But in the Skin settings you have the option to select another OSD layout and one of them has also a very small progressbar.
Thank you for your awnser.. now I have a very small progressbar. Smile
