Hi everybody, got a little problem showing the video file size in the movie info, using the $INFO[ListItem.size] it works only when I brows for files not in the library if someone have an idea
it doesn't work when I browse my video library :
but when I browse my files it works just like a charme
I guess it's either not stored in the library or you have movies in folders.
(2013-03-19, 08:48)Hitcher Wrote: [ -> ]I guess it's either not stored in the library or you have movies in folders.
thanks for your reply "Hitcher" yes right all my movies are in folders each movie with its own folder
Hi, so no answer here? Have You managed toget size in Library view afterall?
(2016-02-28, 15:54)juokelis Wrote: [ -> ]Hi, so no answer here?
Seems not.
I have the same problem now. Wanna show the file size on movie info screen like Lost Alien wanna do. But still the same problem with "0 B"...
He created this thread more than 3 years ago and still no bugfix for that?
Developers please help!
4 years and several kodi versions later and i need to ask if there is a solution meanwhile?
I still wanna use this feature so i can see the filesize in movie info screen (dialog video info).
