Full Version: Video studdering during .avi / .mp4 playback
Hello all,
First time poster, so please be gentle, lol.
1. XMBC 12 - Frodo (Aeon Nox Skin)
2. Win 7 - 64bit Ultimate (Fresh install, no updates, Win 7 basic mode)
  • Intel Q6600
  • Asus P5G41T-N LX Deluxe
  • Sandisk 64GB SSD
  • 2 x 4GB Kingston DDR3 1600Mhz
  • Evga 610 ( Driver Ver. 296.43 )
  • Asus Xonar PCI
  • Hauppauge WinTV-HVR-2250
  • nMedia 2000B
  • XFX 550 Power supply
  • LG BD Reader DVD/RW combo
9. Video studdering during palyback (being streamed from my Win 2k8 R2 storage server via shared folder)
10. Not sure about what the full debug is? its not crashing is a video playback problem.
Sample of a video i'm having problems with...
Complete name                            : V:\Tv Shows\Bedlam\Season 01\bedlam.s01e01.dvdrip.xvid-haggis.avi
Format                                   : AVI
Format/Info                              : Audio Video Interleave
File size                                : 348 MiB
Duration                                 : 43mn 14s
Overall bit rate mode                    : Variable
Overall bit rate                         : 1 127 Kbps
Writing application                      : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library                          : VirtualDubMod build 2540/release
Video
Format                                   : MPEG-4 Visual
Format profile                           : Advanced Simple@L5
Format settings, BVOP                    : 2
Format settings, QPel                    : No
Format settings, GMC                     : No warppoints
Format settings, Matrix                  : Default (H.263)
Muxing mode                              : Packed bitstream
Codec ID                                 : XVID
Codec ID/Hint                            : XviD
Duration                                 : 43mn 14s
Bit rate                                 : 992 Kbps
Width                                    : 624 pixels
Height                                   : 352 pixels
Display aspect ratio                     : 16:9
Frame rate                               : 25.000 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Compression mode                         : Lossy
Bits/(Pixel*Frame)                       : 0.181
Stream size                              : 307 MiB (88%)
Writing library                          : XviD 57
Audio
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 3
Mode                                     : Joint stereo
Mode extension                           : MS Stereo
Codec ID                                 : 55
Codec ID/Hint                            : MP3
Duration                                 : 43mn 14s
Bit rate mode                            : Variable
Bit rate                                 : 121 Kbps
Nominal bit rate                         : 128 Kbps
Channel(s)                               : 2 channels
Sampling rate                            : 48.0 KHz
Stream size                              : 37.5 MiB (11%)
Alignment                                : Aligned on interleaves
Interleave, duration                     : 24 ms (0.60 video frame)
Interleave, preload duration             : 151 ms
Writing library                          : LAME3.98r
Encoding settings                        : -m j -V 4 -q 2 -lowpass 17 --abr 128
So what i've tried so far is,
From System
  • Render method (Various types)
  • Dxva2 on
  • Adjust display refresh rate to match video (On Start/Stop)
From video mode
  • De-interlace Auto
  • Video scaling Auto
  • Post Processing (on)
I have not updated my windows further, as it will be used exclusively as an HTPC, no gaming or functions other than video or music playback. I have tried several videos of different formats and both .avi & .mp4 have studdering, .mkv seem to be ok. I'm not aware of a way of offloading the video (of if its possible) to the video card? I've only discovered XBMC just this week Sad. i've tried to read as much as i'm able too, but i'm only just starting to learn more about this wonderful little program. Any help from the community would be most welcome.
I've moved this from the general to the windows because i believe it to be a codec issue of some sort?
Thanks,
It's hard to say. The two possible causes are Frodo audio output configurations and network issue. Here are some tips- Simplify XBMC configurations......tips on setting up network- post #10....
I still have the same problem with v12.1 (Frodo). Did you find a solution? In my case some full hd videos work fine and others don't. (same for lower qualities)
System:
  • Windows 7 x64
  • XBMC v12.1
  • Gigybyte Z77 D3H
  • i5-3750
  • Asus Xonar DGX PCIe
  • Nvidia 670 GTX
So far I norrowed it down to the Asus sound card. There are two (for me) inacceptable possibilities witch solve the problem. (I've tested them.)
  1. deactivate extension sound card; use on-board sound
  2. downgrade XBMC to previous version 11 and use whatever
This is what I did so far and nothing changed the issue
  • install different drivers:
  • try various XBMC settings (one by one and in combination)
    • audio output: analog 5.1 / audio output device: WASAPI - Speakers... (only WASAPI gives any sound)
    • audio output: HDMI 5.1 / audio output device: WASAPI - Speakers... (only WASAPI gives any sound)
      I get sound via my normal pc speaker if I use WASAPI -HDMI... and deactivate the connected HDMI output in windows settings for sound. Same goes for WASAPI -SPDIF..., but I think it gets redirected because the target is deactivated.
      concluding: only WASAPI - Speakers... working
    • fullscreen window (on/off)
    • render method (auto and DXVA)
    • hardware acceleration (on/off)
    • adjust display refresh rate (allways/off)
    • sync playback to display
edit: I figured out, that everything runs smoothly when I set the XMBC speaker configuration to 2.0 or 4.0 or 7.1. But that's not realy satisfying.
edit2: problem resolved with v12.2
