Full Version: [TV Guide] Extension for HD Homerun Devices
I'm working on an addon extension for the TV Guide addon. This extension is made specifically for HD HomeRun devices and UPnP.
Here is the link to the code.
What this extension does:
The goal of this extension is to keep the xmltv.xml file up to date, as well as modify it to hide channels you are not subscribed to and add the streams to the DB.
Requirements
I've also created a fork for a required update. Link to fork. The update is in the source.py file. You can refer to the readme file in the extensions project. It's pretty straight forward.
Another requirement is to grab a nightly build. The current Frodo release doesn't have a fix for the python's "xbmcvfs.listdir()" method for getting the channels in the UPnP folder.
FYI - I'm new to python, so any advice is helpful.
