Full Version: Problem compiling : ButtonTranslator.cpp
Pages: 1 2
Hi pbrackin,
I had the same problem on Centos 6.6.
I recompiled tinyxml with TINYXML_USE_STL:=YES in tinyxml's makefile
BUT: I didn't put #define TIXML_USE_STL in tinyxml.h
then did
make
ar rc libtinyxml.a tinyxml.o tinyxmlparser.o tinyxmlerror.o tinystr.o
sudo cp libtinyxml.a /usr/local/lib
sudo cp libtinyxml.a /lib
cp tinyxml.h /usr/local/include
cp tinyxml.h /usr/include
cp tinystr.h /usr/local/include
cp tinystr.h /usr/include
then added #define TIXML_USE_STL to XBMCTinyXML.h
and left the #include <tinyxml.h> as it was (and removed all tinyxml related files from xbmc/utils)
then did
make clean
./bootstrap
./configure
make -j2
and it worked fine.
I hope this helps.
Kodi built successfully
Secret was to mod the tinyxml makefile line:
TINYXML_USE_STL := NO
to
TINYXML_USE_STL := YES
and rebuild & re-"install" the tinyxml lib.
I also moved the
#define TINYXML_USE_STL
into ./xbmc/utils/XBMCTinyXML.h and reverted /usr/include/tinyxml.h
Hopefully this will help other CentOS-ers who might face the same issues. Thanks again to all for the help.
Hey zakla -
I just saw ur post after I posted. Wish I saw it earlier. Must've been I didn't see there was a new page in the thread last refresh...
Anyway, thanks for the complete explanation! As you can see - that is pretty much what I finally ended up doing. What an odyssey.
Pages: 1 2
