Full Version: CDArt and Logos Scrape help
Hi all
I have been trying out xbmc 12 and there seems to be a problem with the cdart and logos.
in my movie folder i have
Folder name (movie)
Movie.mkv
movie.nfo
movie.tbn
.Actors (folder)
Extrathumbs (folder)
the problem is when i load a movie into the library it will not get the (disc.png, logo.png and Clearart.png) but it will load the fanart and poster ok. the only way to get the (disc.png, logo.png and Clearart.png) pictures to work is to use the artwork downloader and then its ok. I dont want to do that as its more time consuming. so why will xbmc 12 not load these pictures into the library when you hit i as the poster and fanart do.
i have all these pictures stored and i can not get them into the library only useing the artwork downloader does it work.
thanks for any help
any help on this thanks
i just came across this as well and am looking for a solution..
EDIT: found it.. use artwork downloader, go to advanced setting addon, and active option Use local files and run the addon for fixes this.
(2014-01-12, 12:04)Msan Wrote: [ -> ]use artwork downloader, go to advanced setting addon, and active option Use local files and run the addon for fixes this.
Thanks for this! I was stuck too but have got it working now.
