2013-03-20, 03:38
hi,
i missed the description and image scraping in the mediathek plugin so i decided to create something a little more sophisticated for all the austrian xbmc users. i also implemented a rtmp streaming option , but couldn't get it to work everytime. there seems to be either a problem with the orf stream or the librtmp/rtmpdump. same thing happens if rtmpdump from commandline and try to play the video. but as i mentioned this happens every 10 items you play or something. For now i would recommend you use the shitty low quality mms streams. maybe someone with rtmpdump knowlegde could have a look at it
enjoy
https://github.com/s0faking/plugin.video.orftvthek
[EDIT]
0.3.0
- using parsedom now
- optimized UI/Views
- optimzed images/description scraping
0.2.3
- added sort methods
- fixed error on "themen" items
0.2.2
- fixed parser errors
- "Sendung verpasst?"
0.2.1
- fixed video link parser
0.2.0
- adjusted the addon to the new orf tvthek website
- mp4 streaming is now stable on all platforms!!!
- faster loading times
0.1.3
- added Search function
- fixed the low resolution preview image problem
- added History for Search function
0.1.2
- fixed bad view mode on aeon nox
- added force view option
- Fixed "Missed a Show?" Feature
- A few optimizations for RPI
0.1.1
- Fixed a few Banner/Backdrop Fetching Issues
- Fixed Livestream Exception
- Decreased Loading Time
- Experimental H264 MP4 Stream seams to work on Raspi[omxplayer] (Looks like the XBMC DVDPlayer is the issue)
0.1.0
- Streaming Video from http://tvthek.orf.at (mms)
- Experimental High Quality MP4 Streaming from http://tvthek.orf.at (rtmp)
- Livestream
- Missed Shows
enjoy
[EDIT]
0.3.0
0.2.3
0.2.2
0.2.1
0.2.0
0.1.3
0.1.2
0.1.1
0.1.0
- Livestream
- Missed Shows
