Full Version: Problem: NFS_SERVICE failed
Not sure yet if its Pi or XBMC related, but cross posted here from the XBIAN forums:
Quote:XBian Version : 1.0a5
Overclocking : No
Power supply : D-Link DUB-H7 7 - Port USB 2.0 Hub External
Network connection : LAN 200mb powerline adapters
SD Card : 16GB SD HC
Log Extract:
19:01:48 T:2970612800 DEBUG: CecLogMessage - >> Audio (5) -> Broadcast (F): report physical address (84)
14:28:39 T:3042041856 DEBUG: CGUIMediaWindow::GetDirectory (nfs://192.168.0.100/MediaShare/Movies/HD/Avatar/)
14:28:39 T:3042041856 DEBUG: ParentPath = [nfs://192.168.0.100/MediaShare/Movies/HD/]
14:28:39 T:2848547904 DEBUG: Thread Background Loader 2848547904 terminating
14:28:39 T:2848547904 NOTICE: Thread Jobworker start, auto delete: true
14:28:39 T:2848547904 ERROR: Failed to open(//Movies/HD/Avatar/) nfs_service failed
14:28:39 T:3042041856 ERROR: GetDirectory - Error getting nfs://192.168.0.100/MediaShare/Movies/HD/Avatar/
14:28:39 T:3042041856 ERROR: CGUIMediaWindow::GetDirectory(nfs://192.168.0.100/MediaShare/Movies/HD/Avatar/) failed
14:28:39 T:3042041856 DEBUG: CGUIMediaWindow::GetDirectory (nfs://192.168.0.100/MediaShare/Movies/HD/)
14:28:39 T:3042041856 DEBUG: ParentPath = [sources://video/]
14:28:39 T:2848547904 ERROR: Failed to open(//Movies/HD/) nfs_service failed
14:28:39 T:3042041856 ERROR: CGUIMediaWindow::GetDirectory(nfs://192.168.0.100/MediaShare/Movies/HD/) failed
14:28:39 T:3042041856 DEBUG: OnKey: 167 (a7) pressed, action is Down
14:29:09 T:2848547904 DEBUG: Thread Jobworker 2848547904 terminating (autodelete)
2 ATv2's running same version of XBMC all work fine.
Have also tried connecting the rPi with this v of xbian to the central MySQL database I have but thats failing - will create seperate thread for that.
Any ideas?
I've been requested to update to 12.1 which I'll try later.
In OpenELEC, the XBMC NFS mounts have been unreliable on the Pi for some time - see trac #13324. I boot my Pi with NFS, and OS-based NFS mounts are fine, but accessing NFS from within XBMC is pretty hit & miss, resulting in media that will only play intermittently and worse case, corrupted media libraries due to the scraper picking up bogus information when libNFS goes haywire. Maybe this is what you are experiencing. I'm accessing a FreeNAS 8.3.0-RELEASE NAS.
Updating XBMC inside XBian to 12.1 and all working fine Smile now just need to resolve an issue I have with MySQL on the Pi.
All sussed out and working now Smile there was a hardware issue with the powerline adapter I was using. Replaced that, updated to 12.1, advancedsettings.xml updated with MySQL info, sources.xml copied in so it mirrors my ATV2's.
Everything is working like a dream Smile
