(2013-03-21, 17:28)Eliah Wrote: [ -> ]Give us a mediainfo (http://mediainfo.sourceforge.net/en) of the file.
Seems like it's got 16 refframes
General
CompleteName : E:\Spartacus.Blood.And.Sand.S01\.Spartacus.Blood.and.Sand.S01E02.720p.BluRay.X264-REWARD.mkv
Format : Matroska
Format_Version : Version 2
FileSize/String : 2.19 GiB
Duration/String : 52mn 48s
OverallBitRate/String : 5 925 Kbps
Encoded_Application : x264.exe
Encoded_Library/String : mkv2rls v1.3 (date: 2010 aug 28)
Video
ID/String : 1
Format : AVC
Format/Info : Advanced Video Codec
Format_Profile :
[email protected]
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 5 frames
CodecID : V_MPEG4/ISO/AVC
BitRate/String : 5 282 Kbps
Width/String : 1 280 pixels
Height/String : 720 pixels
DisplayAspectRatio/String : 16:9
FrameRate_Mode/String : Constant
FrameRate/String : 23.976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Bits-(Pixel*Frame) : 0.239
StreamSize/String : 1.91 GiB (87%)
Encoded_Library/String : x264 core 104 r1713 c276662
Encoded_Library_Settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=5282 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language/String : English
Default/String : Yes
Forced/String : No
Audio
ID/String : 2
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Format_Settings_Endianness : Big
CodecID : A_AC3
BitRate_Mode/String : Constant
BitRate/String : 640 Kbps
Channel(s)/String : 6 channels
ChannelPositions : Front: L C R, Side: L R, LFE
SamplingRate/String : 48.0 KHz
BitDepth/String : 16 bits
Compression_Mode/String : Lossy
StreamSize/String : 242 MiB (11%)
Forced/String : No
Text #1
ID/String : 3
Format : UTF-8
CodecID : S_TEXT/UTF8
CodecID/Info : UTF-8 Plain Text
Default/String : No
Forced/String : No
Text #2
ID/String : 4
Format : UTF-8
Language/String : Spanish
Default/String : No
Forced/String : No
Menu
00:00:00.000 : en:00:00:00.000
00:09:14.387 : en:00:09:14.387
00:20:33.274 : en:00:20:33.274
00:30:27.159 : en:00:30:27.159
00:37:10.437 : en:00:37:10.437
00:44:35.339 : en:00:44:35.339
00:50:56.512 : en:00:50:56.512
(2013-03-22, 04:32)ngok Wrote: [ -> ]I think It is not a video format issue but a font render issue.
This happens to asian fonts like Chinese/Japanese/Korean font for there are too many characters for these languages.
Some one has made a patch for eden to reduce the lag by not render the edge of the character.
but it did not merge into the main brunch.
Yes!U R rigt.I'm asian.
And I use the last XBMC is pathed version that pathed by some fans.
Here:https://code.google.com/p/yangapp/downloads/list
But the newest version he doesn't path.
I wish official xbmc group can do this for our asians in next XBMC version.
Thank you very much!
