2013-03-20, 22:45
As mentioned in this thread, I had severe audio issues in Frodo 12.0. In summary, I would have sound in the menus, but when playing a video it would stutter and audio would not work. After pressing stop sound would also be gone in the menus. As you can see from the thread I linked, I managed to get audio working by creating an /etc/asound.conf file. This solution worked pretty well, but from time to time - especially when attempting to stream some HD content - audio would cut out as before. But this happened completely randomly, and rarely.
After upgrading to 12.0 from 12.1 I again experience audio issues. Now, most of the time audio crashes as before when playing a video, even though audio worked in the menus until pressing play. Strangely, some videos do play from time to time, as you can see from the below-mentioned debug log file. However, audio may then just as well crash on playing another video (as evidenced by the same debug log file).
This happens both with the mentioned /etc/asound.conf file present, and with all /etc/asound.conf files and .asoundrc files removed. Pulseaudio is not installed (i am using XBMCbuntu as my underlying distro). Sound hardware in XBMC is set to analog audio, Intel HDA.
I am really puzzled by this, especially since the changelog for 12.1 reads as follows:
Thanks in advance for any help and/or suggestions!
Full XBMC debug log: http://xbmclogs.com/show.php?id=5770
- Line 365-> Plays first video file normally
- Line 557-> Chokes on 2nd video file...
Output of aplay -l
Output of aplay -L
Quote:XBMC no longer hogs audio for Linux and on resume audio will continue to work in LinuxI interpreted this as if the audio bugs/issues I struggled with previously were finally fixed. However, that does not seem to be the case...
Output of aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC892 Analog [ALC892 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 1: ALC892 Digital [ALC892 Digital]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Output of aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
default:CARD=Intel
HDA Intel, ALC892 Analog
Default Audio Device
sysdefault:CARD=Intel
front:CARD=Intel,DEV=0
Front speakers
surround40:CARD=Intel,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Intel,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Intel,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Intel,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Intel,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Intel,DEV=0
HDA Intel, ALC892 Digital
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Intel,DEV=0
Direct sample mixing device
dmix:CARD=Intel,DEV=1
dsnoop:CARD=Intel,DEV=0
Direct sample snooping device
dsnoop:CARD=Intel,DEV=1
hw:CARD=Intel,DEV=0
Direct hardware device without any conversions
hw:CARD=Intel,DEV=1
plughw:CARD=Intel,DEV=0
Hardware device with all software conversions
plughw:CARD=Intel,DEV=1
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
dmix:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
