I got problems to play metacafe movies on my laptop.
22:49:18 T:2632 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:49:18 T:2632 NOTICE: -----------------------------------------------------------------------
22:49:18 T:2632 NOTICE: Starting Kodi (15.0 Git:20150721-2f34a0c). Platform: Windows NT x86 32-bit
22:49:18 T:2632 NOTICE: Using Release Kodi x32 build
22:49:18 T:2632 NOTICE: Kodi compiled Jul 21 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
22:49:18 T:2632 NOTICE: Running on MSI MS-7721 with Windows 7 SP1, kernel: Windows NT x86 64-bit version 6.1
22:49:18 T:2632 NOTICE: Host CPU: AMD A4-4000 APU with Radeon(tm) HD Graphics, 2 cores available
22:49:18 T:2632 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
22:49:18 T:2632 NOTICE: Running with administrator rights
22:49:18 T:2632 NOTICE: Aero is enabled
22:49:18 T:2632 NOTICE: special://xbmc/ is mapped to: G:\Program Files (x86)\Kodi
22:49:18 T:2632 NOTICE: special://xbmcbin/ is mapped to: G:\Program Files (x86)\Kodi
22:49:18 T:2632 NOTICE: special://masterprofile/ is mapped to: G:\Users\Media Center\AppData\Roaming\Kodi\userdata
22:49:18 T:2632 NOTICE: special://home/ is mapped to: G:\Users\Media Center\AppData\Roaming\Kodi\
22:49:18 T:2632 NOTICE: special://temp/ is mapped to: G:\Users\Media Center\AppData\Roaming\Kodi\cache
22:49:18 T:2632 NOTICE: The executable running is: G:\Program Files (x86)\Kodi\Kodi.exe
22:49:18 T:2632 NOTICE: Local hostname: MediaCenter
22:49:18 T:2632 NOTICE: Log File is located: G:\Users\Media Center\AppData\Roaming\Kodi\kodi.log
22:49:18 T:2632 NOTICE: load settings...
22:49:18 T:2632 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
22:49:18 T:2632 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
22:49:18 T:2632 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
22:49:18 T:2632 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
22:49:18 T:2632 NOTICE: Default DVD Player: dvdplayer
22:49:18 T:2632 NOTICE: Default Video Player: dvdplayer
22:49:18 T:2632 NOTICE: Default Audio Player: paplayer
22:49:18 T:2632 NOTICE: Disabled debug logging due to GUI setting. Level 0.
22:49:18 T:2632 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
22:49:18 T:2632 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:49:18 T:2632 NOTICE: Loaded playercorefactory configuration
22:49:18 T:2632 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:49:18 T:2632 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
22:49:18 T:3780 NOTICE: Thread ActiveAE start, auto delete: false
22:49:18 T:2224 NOTICE: Thread AESink start, auto delete: false
22:49:18 T:3780 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "1 - LG TV (AMD High Definition Audio Device)" seems to be not supported.
22:49:18 T:3780 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "1 - LG TV (AMD High Definition Audio Device)" seems to be not supported.
22:49:18 T:3780 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "1 - LG TV (AMD High Definition Audio Device)" seems to be not supported.
22:49:18 T:3780 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "1 - LG TV (AMD High Definition Audio Device)" seems to be not supported.
22:49:18 T:3780 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "Głośniki (SB X-Fi Surround 5.1 Pro)" seems to be not supported.
22:49:18 T:3780 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "Cyfrowy interfejs audio (SB X-Fi Surround 5.1 Pro)" seems to be not supported.
22:49:18 T:3780 NOTICE: Found 2 Lists of Devices
22:49:18 T:3780 NOTICE: Enumerated DIRECTSOUND devices:
22:49:18 T:3780 NOTICE: Device 1
22:49:18 T:3780 NOTICE: m_deviceName : {32C08483-C3DE-4FB8-B236-D414210EB088}
22:49:18 T:3780 NOTICE: m_displayName : HDMI - 1 - LG TV (AMD High Definition Audio Device)
22:49:18 T:3780 NOTICE: m_displayNameExtra: DIRECTSOUND: 1 - LG TV (AMD High Definition Audio Device)
22:49:18 T:3780 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
22:49:18 T:3780 NOTICE: m_channels : FL,FR
22:49:18 T:3780 NOTICE: m_sampleRates : 48000
22:49:18 T:3780 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
22:49:18 T:3780 NOTICE: Device 2
22:49:18 T:3780 NOTICE: m_deviceName : default
22:49:18 T:3780 NOTICE: m_displayName : default
22:49:18 T:3780 NOTICE: Device 3
22:49:18 T:3780 NOTICE: m_deviceName : {3FF202ED-456C-435A-9F47-85713C9E8F45}
22:49:18 T:3780 NOTICE: m_displayName : Speakers - Głośniki (SB X-Fi Surround 5.1 Pro)
22:49:18 T:3780 NOTICE: m_displayNameExtra: DIRECTSOUND: Głośniki (SB X-Fi Surround 5.1 Pro)
22:49:18 T:3780 NOTICE: m_deviceType : AE_DEVTYPE_PCM
22:49:18 T:3780 NOTICE: Device 4
22:49:18 T:3780 NOTICE: m_deviceName : {F7493FE3-867E-4BAE-9FB0-46CF66AFAB0A}
22:49:18 T:3780 NOTICE: m_displayName : Digital Passthrough - Cyfrowy interfejs audio (SB X-Fi Surround 5.1 Pro)
22:49:18 T:3780 NOTICE: m_displayNameExtra: DIRECTSOUND: Cyfrowy interfejs audio (SB X-Fi Surround 5.1 Pro)
22:49:18 T:3780 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
22:49:18 T:3780 NOTICE: Enumerated WASAPI devices:
22:49:18 T:3780 NOTICE: m_displayNameExtra: WASAPI: 1 - LG TV (AMD High Definition Audio Device)
22:49:18 T:3780 NOTICE: m_sampleRates : 192000,96000,48000,44100,32000
22:49:18 T:3780 NOTICE: m_dataFormats : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
22:49:18 T:3780 NOTICE: m_displayNameExtra: WASAPI: Głośniki (SB X-Fi Surround 5.1 Pro)
22:49:18 T:3780 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR
22:49:18 T:3780 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
22:49:18 T:3780 NOTICE: m_displayNameExtra: WASAPI: Cyfrowy interfejs audio (SB X-Fi Surround 5.1 Pro)
22:49:18 T:3780 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
22:49:18 T:2632 NOTICE: Running database version Addons19
22:49:19 T:2632 NOTICE: ADDONS: Using repository repository.xbmc.org
22:49:19 T:2632 NOTICE: ADDONS: Using repository repository.sd-xbmc.org
22:49:20 T:4072 NOTICE: Thread PeripBusCEC start, auto delete: false
22:49:20 T:3104 NOTICE: Thread RemoteControl start, auto delete: false
22:49:20 T:3140 NOTICE: Thread PeripBusUSB start, auto delete: false
22:49:20 T:2632 NOTICE: Found screen: Rodzajowy monitor PnP on AMD Radeon HD 7480D, adapter 0.
22:49:20 T:2632 NOTICE: Primary mode: 1920x1080@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 640x480@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 640x480@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 640x480@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Previous line repeats 2 times.
22:49:20 T:2632 NOTICE: Additional mode: 640x480@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 640x480@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 640x480@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x480@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x480@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x480@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x480@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x480@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x480@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x576@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x576@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x576@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x576@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x576@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x576@ 59.94 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x576@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 720x576@ 25.00i - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x480@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x480@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x480@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x480@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x480@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x480@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x480@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x600@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x600@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x600@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x600@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x600@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x600@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x600@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x600@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x600@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x600@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x600@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x600@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x600@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x768@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x768@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x768@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x768@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x768@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x768@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1152x648@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1152x648@ 59.94 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1152x648@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1152x864@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1152x864@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1152x864@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1152x864@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1152x864@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1152x864@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x720@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x720@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x720@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x720@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x720@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x768@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x768@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x768@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x768@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x768@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x768@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x960@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x960@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x960@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x960@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x960@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x960@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x1024@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x1024@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x1024@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x1024@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x1024@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x1024@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1360x768@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1360x768@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1360x768@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1360x768@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1360x768@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1360x768@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1400x1050@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1400x1050@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1400x1050@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1400x1050@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1400x1050@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1400x1050@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1400x1050@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1400x1050@ 59.94 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1600x900@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1600x900@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1600x900@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1600x900@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1600x900@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1600x900@ 59.94 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1680x1050@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1680x1050@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1680x1050@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1680x1050@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1680x1050@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1680x1050@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1776x1000@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1776x1000@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1776x1000@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1776x1000@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1776x1000@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1776x1000@ 59.94 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1776x1000@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1776x1000@ 25.00i - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1776x1000@ 29.97i - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1776x1000@ 30.00i - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1920x1080@ 24.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1920x1080@ 23.98 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1920x1080@ 25.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1920x1080@ 30.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1920x1080@ 29.97 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
22:49:20 T:2632 NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
22:49:20 T:2632 NOTICE: Checking resolution 16
22:49:21 T:2632 NOTICE: Running database version Addons19
22:49:21 T:2632 NOTICE: Running database version ViewModes6
22:49:21 T:2632 NOTICE: Running database version Textures13
22:49:21 T:2632 NOTICE: Running database version MyMusic52
22:49:21 T:2632 NOTICE: Running database version MyVideos93
22:49:21 T:2632 NOTICE: Running database version TV29
22:49:21 T:2632 NOTICE: Running database version Epg10
22:49:22 T:2632 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
22:49:22 T:2632 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
22:49:22 T:2632 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
22:49:22 T:2632 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
22:49:22 T:2516 NOTICE: Thread LanguageInvoker start, auto delete: false
22:49:22 T:2632 NOTICE: initialize done
22:49:22 T:3928 NOTICE: Thread LanguageInvoker start, auto delete: false
22:49:22 T:2516 NOTICE: Previous line repeats 1 times.
22:49:22 T:2516 NOTICE: -->Python Interpreter Initialized<--
22:49:22 T:2632 NOTICE: Previous line repeats 2 times.
22:49:22 T:2632 NOTICE: Running the application...
22:49:22 T:3148 NOTICE: Thread JobWorker start, auto delete: true
22:49:22 T:2632 NOTICE: starting upnp client
22:49:22 T:2632 NOTICE: ES: Starting event server
22:49:22 T:4056 NOTICE: Thread EventServer start, auto delete: false
22:49:22 T:4056 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
22:49:22 T:4056 NOTICE: UDP: Listening on port 9777
22:49:22 T:3524 NOTICE: Thread TCPServer start, auto delete: false
22:49:22 T:3552 NOTICE: Thread RSSReader start, auto delete: false
22:49:22 T:1912 NOTICE: StorageServer Module loaded RUN
22:49:22 T:1912 NOTICE: StorageClient-2.5.4 Starting server
22:49:27 T:3964 NOTICE: Thread JobWorker start, auto delete: true
22:49:33 T:3368 NOTICE: Thread LanguageInvoker start, auto delete: false
22:49:33 T:3368 NOTICE: -->Python Interpreter Initialized<--
22:49:34 T:3368 NOTICE: [xbmcswift2] Request for "/" matches rule for function "show_categories"
22:49:34 T:3368 NOTICE: XBMC Add-on Metacafe scraper: __get_tree opening url: http://www.metacafe.com/videos_about/
22:49:34 T:3368 NOTICE: XBMC Add-on Metacafe scraper: __get_tree got 70640 bytes
22:49:34 T:1144 NOTICE: Thread BackgroundLoader start, auto delete: false
22:49:35 T:3732 NOTICE: Thread LanguageInvoker start, auto delete: false
22:49:35 T:3732 NOTICE: -->Python Interpreter Initialized<--
22:49:35 T:3732 NOTICE: [xbmcswift2] Request for "/videos/%2Fvideos_about%2F/" matches rule for function "show_videos"
22:49:35 T:3732 NOTICE: XBMC Add-on Metacafe scraper: __get_tree opening url: http://www.metacafe.com/videos_about/
22:49:35 T:3732 NOTICE: XBMC Add-on Metacafe scraper: __get_tree got 70640 bytes
22:49:35 T:3836 NOTICE: Thread BackgroundLoader start, auto delete: false
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2849324
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/642115
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1759809
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2473547
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2835788
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2489217
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3548346
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2791340
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3026175
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/694805
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1403360
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2617718
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2097258
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2132022
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3943787
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3674729
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2676448
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2070963
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2532315
22:49:36 T:3148 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1342316
22:49:37 T:2788 NOTICE: Thread LanguageInvoker start, auto delete: false
22:49:37 T:2788 NOTICE: -->Python Interpreter Initialized<--
22:49:37 T:2788 NOTICE: [xbmcswift2] Request for "/video/2676448" matches rule for function "play_video"
22:49:37 T:2788 NOTICE: XBMC Add-on Metacafe scraper: __get_tree opening url: http://www.metacafe.com/api/item/2676448/
22:49:37 T:2788 NOTICE: XBMC Add-on Metacafe scraper: __get_tree got 3006 bytes
22:49:37 T:2788 NOTICE: XBMC Add-on Metacafe scraper: get_video_urls opening url: http://www.metacafe.com/fplayer/2676448/pull_dog_across_river.swf
22:49:37 T:2788 NOTICE: [plugin.video.metacafe] Using URL: http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%202676448.10234982.11.flv?__gda__=1438814978_33f9cf8aa994db44a0aab6dbf7082cfa
22:49:38 T:2632 NOTICE: DVDPlayer: Opening: http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%202676448.10234982.11.flv?__gda__=1438814978_33f9cf8aa994db44a0aab6dbf7082cfa
22:49:38 T:2632 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
22:49:38 T:2632 NOTICE: DXVA::CProcessorHD::PreInit - The Direct3d device doesn't support DXVA-HD.
22:49:38 T:2632 NOTICE: CWinRenderer::Preinit - could not init DXVA-HD processor - skipping
22:49:38 T:3088 NOTICE: Thread DVDPlayer start, auto delete: false
22:49:38 T:3088 NOTICE: Creating InputStream
22:49:38 T:3088 ERROR: CCurlFile::Open failed with code 404 for http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%202676448.10234982.11.flv?__gda__=1438814978_33f9cf8aa994db44a0aab6dbf7082cfa
22:49:38 T:3088 ERROR: XFILE::CFileCache::Open - failed to open source <http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%202676448.10234982.11.flv?__gda__=1438814978_33f9cf8aa994db44a0aab6dbf7082cfa>
22:49:38 T:3088 ERROR: CDVDPlayer::OpenInputStream - error opening [http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%202676448.10234982.11.flv?__gda__=1438814978_33f9cf8aa994db44a0aab6dbf7082cfa]
22:49:38 T:3088 NOTICE: CDVDPlayer::OnExit()
22:49:38 T:2632 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.metacafe/video/2676448]
22:49:38 T:320 NOTICE: Thread BackgroundLoader start, auto delete: false
22:49:38 T:2632 NOTICE: CDVDPlayer::CloseFile()
22:49:38 T:2632 NOTICE: DVDPlayer: waiting for threads to exit
22:49:38 T:2632 NOTICE: DVDPlayer: finished waiting
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2849324
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/642115
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1759809
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2473547
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2835788
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2489217
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3548346
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2791340
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3026175
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/694805
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1403360
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2617718
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2097258
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2132022
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3943787
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3674729
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2676448
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2070963
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2532315
22:49:39 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1342316
22:49:43 T:3528 NOTICE: Thread LanguageInvoker start, auto delete: false
22:49:43 T:3528 NOTICE: -->Python Interpreter Initialized<--
22:49:43 T:3528 NOTICE: [xbmcswift2] Request for "/video/3674729" matches rule for function "play_video"
22:49:43 T:3528 NOTICE: XBMC Add-on Metacafe scraper: __get_tree opening url: http://www.metacafe.com/api/item/3674729/
22:49:43 T:3528 NOTICE: XBMC Add-on Metacafe scraper: __get_tree got 2687 bytes
22:49:43 T:3528 NOTICE: XBMC Add-on Metacafe scraper: get_video_urls opening url: http://www.metacafe.com/fplayer/3674729/the_biggest_runner.swf
22:49:44 T:3528 NOTICE: [plugin.video.metacafe] Using URL: http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%203674729.12189984.11.flv?__gda__=1438814984_1204640050852f4f933a9c0ad3712bf5
22:49:44 T:2632 NOTICE: DVDPlayer: Opening: http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%203674729.12189984.11.flv?__gda__=1438814984_1204640050852f4f933a9c0ad3712bf5
22:49:44 T:2632 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
22:49:44 T:2632 NOTICE: DXVA::CProcessorHD::PreInit - The Direct3d device doesn't support DXVA-HD.
22:49:44 T:2632 NOTICE: CWinRenderer::Preinit - could not init DXVA-HD processor - skipping
22:49:44 T:3720 NOTICE: Thread DVDPlayer start, auto delete: false
22:49:44 T:3720 NOTICE: Creating InputStream
22:49:45 T:3720 ERROR: CCurlFile::Open failed with code 404 for http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%203674729.12189984.11.flv?__gda__=1438814984_1204640050852f4f933a9c0ad3712bf5
22:49:45 T:3720 ERROR: XFILE::CFileCache::Open - failed to open source <http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%203674729.12189984.11.flv?__gda__=1438814984_1204640050852f4f933a9c0ad3712bf5>
22:49:45 T:3720 ERROR: CDVDPlayer::OpenInputStream - error opening [http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%203674729.12189984.11.flv?__gda__=1438814984_1204640050852f4f933a9c0ad3712bf5]
22:49:45 T:3720 NOTICE: CDVDPlayer::OnExit()
22:49:45 T:2632 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.metacafe/video/3674729]
22:49:45 T:3296 NOTICE: Thread BackgroundLoader start, auto delete: false
22:49:45 T:2632 NOTICE: CDVDPlayer::CloseFile()
22:49:45 T:2632 NOTICE: DVDPlayer: waiting for threads to exit
22:49:45 T:2632 NOTICE: DVDPlayer: finished waiting
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2849324
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/642115
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1759809
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2473547
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2835788
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2489217
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3548346
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2791340
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3026175
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/694805
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1403360
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2617718
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2097258
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2132022
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3943787
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3674729
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2676448
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2070963
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2532315
22:49:45 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1342316
22:49:47 T:3220 NOTICE: Thread LanguageInvoker start, auto delete: false
22:49:47 T:3220 NOTICE: -->Python Interpreter Initialized<--
22:49:47 T:3220 NOTICE: [xbmcswift2] Request for "/video/3943787" matches rule for function "play_video"
22:49:47 T:3220 NOTICE: XBMC Add-on Metacafe scraper: __get_tree opening url: http://www.metacafe.com/api/item/3943787/
22:49:47 T:3220 NOTICE: XBMC Add-on Metacafe scraper: __get_tree got 2620 bytes
22:49:47 T:3220 NOTICE: XBMC Add-on Metacafe scraper: get_video_urls opening url: http://www.metacafe.com/fplayer/3943787/how_to_cut_bottle.swf
22:49:47 T:3220 NOTICE: [plugin.video.metacafe] Using URL: http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%203943787.12694859.11.flv?__gda__=1438814988_55b26cd92dd437e83f3f02f08b5470f6
22:49:47 T:2632 NOTICE: DVDPlayer: Opening: http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%203943787.12694859.11.flv?__gda__=1438814988_55b26cd92dd437e83f3f02f08b5470f6
22:49:47 T:2632 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
22:49:47 T:2632 NOTICE: DXVA::CProcessorHD::PreInit - The Direct3d device doesn't support DXVA-HD.
22:49:47 T:2632 NOTICE: CWinRenderer::Preinit - could not init DXVA-HD processor - skipping
22:49:47 T:2808 NOTICE: Thread DVDPlayer start, auto delete: false
22:49:47 T:2808 NOTICE: Creating InputStream
22:49:48 T:2808 ERROR: CCurlFile::Open failed with code 404 for http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%203943787.12694859.11.flv?__gda__=1438814988_55b26cd92dd437e83f3f02f08b5470f6
22:49:48 T:2808 ERROR: XFILE::CFileCache::Open - failed to open source <http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%203943787.12694859.11.flv?__gda__=1438814988_55b26cd92dd437e83f3f02f08b5470f6>
22:49:48 T:2808 ERROR: CDVDPlayer::OpenInputStream - error opening [http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%203943787.12694859.11.flv?__gda__=1438814988_55b26cd92dd437e83f3f02f08b5470f6]
22:49:48 T:2808 NOTICE: CDVDPlayer::OnExit()
22:49:48 T:2632 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.metacafe/video/3943787]
22:49:48 T:1464 NOTICE: Thread BackgroundLoader start, auto delete: false
22:49:48 T:2632 NOTICE: CDVDPlayer::CloseFile()
22:49:48 T:2632 NOTICE: DVDPlayer: waiting for threads to exit
22:49:48 T:2632 NOTICE: DVDPlayer: finished waiting
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2849324
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/642115
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1759809
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2473547
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2835788
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2489217
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3548346
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2791340
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3026175
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/694805
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1403360
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2617718
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2097258
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2132022
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3943787
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3674729
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2676448
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2070963
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2532315
22:49:48 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1342316
22:49:50 T:3540 NOTICE: Thread LanguageInvoker start, auto delete: false
22:49:50 T:3540 NOTICE: -->Python Interpreter Initialized<--
22:49:50 T:3540 NOTICE: [xbmcswift2] Request for "/video/2132022" matches rule for function "play_video"
22:49:50 T:3540 NOTICE: XBMC Add-on Metacafe scraper: __get_tree opening url: http://www.metacafe.com/api/item/2132022/
22:49:50 T:3540 NOTICE: XBMC Add-on Metacafe scraper: __get_tree got 4913 bytes
22:49:50 T:3540 NOTICE: XBMC Add-on Metacafe scraper: get_video_urls opening url: http://www.metacafe.com/fplayer/2132022/very_funny_advert_romantic_date.swf
22:49:51 T:3540 NOTICE: [plugin.video.metacafe] Using URL: http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%202132022.9051387.11.flv?__gda__=1438814991_43b1aff24f70d2dae6a306f593ffe2c4
22:49:51 T:2632 NOTICE: DVDPlayer: Opening: http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%202132022.9051387.11.flv?__gda__=1438814991_43b1aff24f70d2dae6a306f593ffe2c4
22:49:51 T:2632 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
22:49:51 T:2632 NOTICE: DXVA::CProcessorHD::PreInit - The Direct3d device doesn't support DXVA-HD.
22:49:51 T:2632 NOTICE: CWinRenderer::Preinit - could not init DXVA-HD processor - skipping
22:49:51 T:2920 NOTICE: Thread DVDPlayer start, auto delete: false
22:49:51 T:2920 NOTICE: Creating InputStream
22:49:52 T:2920 ERROR: CCurlFile::Open failed with code 404 for http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%202132022.9051387.11.flv?__gda__=1438814991_43b1aff24f70d2dae6a306f593ffe2c4
22:49:52 T:2920 ERROR: XFILE::CFileCache::Open - failed to open source <http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%202132022.9051387.11.flv?__gda__=1438814991_43b1aff24f70d2dae6a306f593ffe2c4>
22:49:52 T:2920 ERROR: CDVDPlayer::OpenInputStream - error opening [http://vl.mccont.com/ItemFiles/%5BFrom%20www.metacafe.com%5D%202132022.9051387.11.flv?__gda__=1438814991_43b1aff24f70d2dae6a306f593ffe2c4]
22:49:52 T:2920 NOTICE: CDVDPlayer::OnExit()
22:49:52 T:2632 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.metacafe/video/2132022]
22:49:52 T:272 NOTICE: Thread BackgroundLoader start, auto delete: false
22:49:52 T:2632 NOTICE: CDVDPlayer::CloseFile()
22:49:52 T:2632 NOTICE: DVDPlayer: waiting for threads to exit
22:49:52 T:2632 NOTICE: DVDPlayer: finished waiting
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2849324
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/642115
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1759809
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2473547
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2835788
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2489217
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3548346
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2791340
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3026175
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/694805
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1403360
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2617718
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2097258
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2132022
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3943787
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/3674729
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2676448
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2070963
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/2532315
22:49:52 T:3964 WARNING: XFILE::CFileFactory::CreateLoader - unsupported protocol(plugin) in plugin://plugin.video.metacafe/video/1342316
22:49:52 T:1924 NOTICE: Thread LanguageInvoker start, auto delete: false
22:49:52 T:1924 NOTICE: -->Python Interpreter Initialized<--
22:49:53 T:1924 NOTICE: [xbmcswift2] Request for "/" matches rule for function "show_categories"
22:49:53 T:1924 NOTICE: XBMC Add-on Metacafe scraper: __get_tree opening url: http://www.metacafe.com/videos_about/
22:49:53 T:1924 NOTICE: XBMC Add-on Metacafe scraper: __get_tree got 70640 bytes
22:49:53 T:3408 NOTICE: Thread BackgroundLoader start, auto delete: false
22:49:54 T:2632 NOTICE: Storing total System Uptime
22:49:54 T:2632 NOTICE: Saving settings
22:49:54 T:2632 NOTICE: stop all
22:49:54 T:2632 NOTICE: stop player
22:49:54 T:2632 NOTICE: ES: Stopping event server
22:49:54 T:2632 NOTICE: stopping upnp
22:49:55 T:4056 NOTICE: ES: UDP Event server stopped
22:49:55 T:2632 NOTICE: stop sap announcement listener
22:49:55 T:2632 NOTICE: clean cached files!
22:49:55 T:2632 NOTICE: unload skin
22:49:55 T:1912 NOTICE: StorageServer-2.5.4 Closed down
22:49:55 T:2632 NOTICE: stopped
22:49:55 T:2632 NOTICE: destroy
22:49:55 T:2632 NOTICE: closing down remote control service
22:49:57 T:2632 NOTICE: unload sections
22:49:57 T:2632 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:49:57 T:2632 NOTICE: destroy
22:49:57 T:2632 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
22:49:57 T:2632 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
22:49:57 T:2632 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
22:49:57 T:2632 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
22:49:57 T:2632 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
22:49:57 T:2632 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
22:49:57 T:2632 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
22:49:57 T:2632 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
22:49:57 T:2632 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
22:49:57 T:2632 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
22:49:57 T:2632 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
22:49:57 T:2632 NOTICE: closing down remote control service
22:49:57 T:2632 NOTICE: application stopped...
22:49:57 T:2632 ERROR: dllFreeLibrary - Invalid hModule specified
