2013-03-21, 04:28
I have two different XBMC's running in my living room. As such, I would like to control them independently. I use a standard MCE remote, which works out-of-the-box with XBMC (wonderful !)
But one remote causes action on both XBMC's (confusing).
Easy solution, I think. MCE remotes first send an ID ahead of each command (defaults to "1"). See below on how to change that ID on the remote (e.g. to "2"). Now the kicker : How do I get XBMC to change the remote control ID that he's expecting (i.e. change it from "1" to "2")
NOTE : How to change the MCE remote to a different ID --> press and hold the DVD Menu button on the remote control, then press a number button (1-8) for five seconds. Remote controls with visible LED signal indicators will blink twice to confirm the change.
Thanks !
-Chad
Thanks !
-Chad
