2013-03-21, 13:36
First off Great work guys this really is a great skin, and I am enjoying playing with it, so far so good. I have a couple of questions that I hope you would be able to help me with
1. When I go into my music menu and select an album and play the first track i have to go back to the main menu to see the info about the artist and the artist slideshow - is this normal? or can it be played from within the music menu? If it is possible how do you configure this?
2. following on from the question above how do you make the artist slideshow Full Screen without having to press the Full Screen Button? If this is possible can you explain how to configure this? I do notice that if you leave the main screen after a couple of minutes it goes to full screen by default, perhaps this time can be configured also?
3. How can you move the Main Menu Items to diffrent positions as I have setup some custom menus but they do not appear in order for instance the music menu is in between two of my custom menus and I want it to be at the end? Is it possible to move a menu item from one position to another? If so could you explain how?
Hope the above is possible and I'm just being silly and cannot find the settings to change it
Thanks in advance
Mark
Thanks in advance
Mark
