2013-03-21, 18:16
I got a xbmc HTPC, running the newest xbmcbuntu 12, which has an anoying issue.
The rear volume is really low, and i can't boost it anywhere.
The front and center volume is normal though.
Alsamixer only reports a pcm, CMSS led, and power led control.
I have been searching a few weeks for a solution, but i can't find the fix.
I'm using a usb soundcard (Creative soundblaster Live! 24 bit external usb)
hooked up to an 5.1 analog speakerset.
Did anyone experience the same issue, and found a fix for it?
