Today i went to use my vu plus pvr on my mac but all of a sudden it has stopped working? I have tried disabling, re-enabling etc.
I just get the same message saying that no pvr clients have been started yet?
Is anybody else experiencing this?
the logs say the following:
08:18:41 T:2958716928 NOTICE: AddOnLog: VU+ / Enigma2 Client: Open - VU+ Addon Configuration options
08:18:41 T:2958716928 NOTICE: AddOnLog: VU+ / Enigma2 Client: Open - Hostname: '192.168.1.84'
08:18:41 T:2958716928 NOTICE: AddOnLog: VU+ / Enigma2 Client: Open - WebPort: '80'
08:18:41 T:2958716928 NOTICE: AddOnLog: VU+ / Enigma2 Client: Open - StreamPort: '8001'
08:18:41 T:2958716928 WARNING: FillBuffer: curl failed with code 22
08:18:41 T:2958716928 ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
08:18:41 T:2958716928 ERROR: Open - failed to open source <http://192.168.1.84:80/web/deviceinfo>
08:18:41 T:2958716928 ERROR: AddOnLog: VU+ / Enigma2 Client: Open It seem's that the webinterface cannot be reached. Make sure that you set the correct configuration options in the addon settings!
08:18:41 T:2958716928 ERROR: ADDON: Dll VU+ / Enigma2 Client - Client returned bad status (1) from Create and is not usable
08:18:41 T:2958716928 WARNING: UpdateAndInitialiseClients - failed to create add-on VU+ / Enigma2 Client, status = 1
08:18:41 T:2952859648 NOTICE: Thread CAddonStatusHandler:pvr.vuplus start, auto delete: true
(2013-03-23, 10:04)dhod Wrote: [ -> ]the logs say the following:
Did you update your vuplus? The deviceinfo web api call doesn't work in the newer openwebif versions. I already created a PR to fix this, but Lars didn't pull it in yet.
Ah ok then, yeah it's probably that then. Do you think it will be included in the next release?
Dan
hi friends, here the same problem, I updated my solo 2 (Vix Image) and now cant connect
Opdenkamp didn't pull it in yet :/
Not in yet - did you upgrade to the newest openwebif? Maybe it is fixed in there again...
Yeah i upgraded to the latest stable last night and all working again now!
I just closed the PR then - if it is fixed within openwebif, no need for a workaround then.
